Auto Locking hub squeaking...
Old Sep 28, 2021 | 06:44 PM
ViperGreg's Avatar
ViperGreg
Hello all,
I have a 94 F150 4x4 with the auto-locking hubs. The drivers side is emitting a high-pitched squeaking sound when driving. From what I have read, everyone just converts these to manual hubs instead of fixing these automatic hubs. If I switch to the manual hubs, would that eliminate the squeaking issue?
Thanks!
Old Sep 29, 2021 | 07:28 AM
Birdhunter1's Avatar
Birdhunter1
Possibly, but from what I remember there isn't much in the hub that would squeak. I more often found that squeak noises came out of the brakes somehow and once in a while the bearing might be shot and start squeaking. There is also a bearing inside the spindle that can wear out and squeal when the hubs are engaged, if the hubs aren't engaged that bearing doesn't see any movement on it.
Old Sep 29, 2021 | 10:45 AM
Mudsport96's Avatar
Mudsport96
My bet is that the hub is engaged and the shaft has been turning. And this bearing is what he is hearing.
The autos were a good concept on paper, but not in practice. Mine let me down exactly once before being replaced.
Old Sep 29, 2021 | 01:07 PM
Encho's Avatar
Encho
The Southernmost Mod
Hello, in my signature you'll find the replacement procedure, and also in that thread, there are pictures of the various bearings that could be causing the noise you're hearing.
Old Sep 29, 2021 | 01:10 PM
ViperGreg's Avatar
ViperGreg
Thanks for the replies. I'll look through the write-up and also verify that the hub is disengaged from the axle. I just don't want to install manual hubs and then still have the same squeaking issue!
Old Sep 29, 2021 | 01:20 PM
Birdhunter1
Swapping out the auto hub for the manual locking hubs is as simple as getting a set and swapping them, Warn and Mile Markers hubs are quite popular, the Warn Standard hubs for that axle are about $100-120, very durable and I think the kit comes with everything you need to swap them, might have to change the spindle nuts. At the same time its not a bad idea to repack the bearings and replace the seals AND swap out that bearing inside of the spindle. Most often times the originals rust and self destruct because they just don't get used or greased.
Old Sep 29, 2021 | 05:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Remove the auto hubs then drive the truck to see if the noise is still there.
Ikes_Fseries
Apr 30, 2009 07:49 AM
csangster
Jan 21, 2008 08:31 AM
LeeroyDiesel
Sep 11, 2006 02:03 PM
mary-kate
General Automotive Discussion
32
Dec 28, 2004 04:40 PM
godsmk
1978 - 1996 Big Bronco
Nov 22, 2000 03:14 PM
