rust proofing
Old Sep 28, 2021 | 05:18 PM
fordman19762003's Avatar
fordman19762003
Another vote for Fluid Film, it's well worth the little bit of extra work.
ETA. I spray everything the same as if it was an all steel truck, it's not going to hurt anything.
Old Sep 28, 2021 | 06:19 PM
blackdog2086's Avatar
blackdog2086
I use a 2 step process. First, I coat with cosmoline which is extremely tacky and goes on in a thin layer. After letting that dry for a day I go over it with fluid film. My reasoning is that if the fluid film which remains somewhat well.....fluid gets brushed or sprayed off in areas, I still have an extra layer of protection. 2 to 3 cans will easily do a Superduty and it's available on Amazon .
https://www.cosmolinedirect.com/cosm...st-preventive/
Old Jun 28, 2022 | 08:53 PM
jstenger's Avatar
jstenger
4wd Low
Originally Posted by M1A4ME
When I bought my new F250 I mentioned I wanted to get the bed sprayed with bed liner. They recommended LineX. I asked some questions and they also mentioned that the local LineX shop also undercoated vehicles.
I decided to go with both, bed and undercoating. Made the assumption that the undercoating was as good as the bed liner material which is pretty darn tough and lasts seemingly for ever. But I really have no idea how good their undercoating may be. The bottom of the truck/frame sure looks pretty though.
I have an appointment at the local LineX dealer in 2 weeks for bedliner and undercoating. They are also pushing their rustproofing for the body. They claim it helps fight corrosion. Did your LineX dealer try to talk you into rustproofing also? Also, how does your undercoating look after being on there for a while?
Old Jun 28, 2022 | 09:05 PM
morehouse7's Avatar
morehouse7
I don't know what Line-X undercoats frames with but I wouldn't use anything that's like their bedliner stuff. Stick with Fluid Film or Krown or any other oil based preventative. The rubberized ones can be a death sentence trapping and destroying under the coating, Here in the NE anyways it's gone horribly wrong most times I have seen..
Old Jun 28, 2022 | 09:18 PM
jstenger's Avatar
jstenger
4wd Low
The LineX dealer by me uses an asphalt based undercoating. It is not rubberized and it is not the same material as the bedliner.
Old Jun 29, 2022 | 03:26 AM
ToMang07's Avatar
ToMang07
I use NH Oil undercoating, usually in the late summer/early fall. it holds up real well to road wash, and frankly looks better than Fluid Film. My brother had the Ford dealer undercoat his truck when he bought it (new) and with half the miles my truck had most of it was washed off, and he had a good bit of rust on all the driveline/suspension components. Mine still looked like new.
Old Jun 30, 2022 | 05:11 AM
connman12's Avatar
connman12
Same here… with the NH Oil… Had mine done 3 weeks ago..( 22 Platinum ) .. Here in the North East… Heavy Salt and Brined Roads.. create havoc…on any vehicle…
Old Jun 30, 2022 | 07:12 AM
speakerfritz's Avatar
speakerfritz
the electrical wires on the alumiduty seems to have inherently more corrosion problems than the steel superduty's. must be some type of galvanic reaction. a light corrosion prevention fluid that does not dry out and interfree with connectors is what I am looking for.
Old Jul 2, 2022 | 05:55 AM
Jacksdad99's Avatar
Jacksdad99
Absolutely. You do not want any sort of permanent encapsulating product on your frame.
Old Jul 4, 2022 | 10:58 AM
acdii's Avatar
acdii
What those "permanent" undercoatings have happen that leads to rust is when a rock hits it just right, it can puncture the surface and leave a tiny balloon of open space under it where moisture collects, then a year later you have a rust patch under the coating. Same thing happens to E-Coat. I am finishing up restoring the bed of my 2012 and Ford doesn't paint the underside of the bed, they rely on the E-Coat to protect the metal. Thats all fine and dandy if the truck is never driven, but when ever a rock strikes the surface, it created a bubble under the Ecoat and eventually it will rust. I found thousands of little pock marks under the E-Coat while sanding and grinding.
IOW don't use any Permanent type coating on the chassis and expect it to prevent rust, it wont. Fluid Film, Wool Wax, and the like are much better at preventing rust on the frame. As far as the body, it's Aluminum, it will last decades without doing anything but simple washes. Unlike earlier aluminum panels that were attached to a steel structure, the entire truck body, except the firewall is Aluminum, so no chance of dissimilar metal corrosion. The Firewall is isolated with a special adhesive to prevent contact. Putting any "rust Proofing" on the aluminum body is a waste of time and money.
My vote is FF or WW.
mattymax
May 28, 2015 08:23 PM
LARIAT 85
Jan 12, 2011 09:38 AM
dspeer75
Paint & Bodywork
Feb 22, 2009 11:00 AM
Ford150/428/dud
Paint & Bodywork
Apr 21, 2005 02:00 PM
Powerstroke baby
Paint & Bodywork
Sep 28, 2003 03:46 PM
