Trailer TPMS help in pairing
Old Jul 3, 2022 | 09:48 PM
Fowlthing's Avatar
Fowlthing
I have the equipment from Ford. Have it hooked up. But can only pair the first tire on the trailer ?
The owners manual says to hit the hazard lights off and on 3 times. The instructions with the equipment says to let air off today the tire to train it to the truck.
i also have a pairing device the el-50448.
i can get the first tire to pair. The tire symbol turns green and goes to the next tire. But can’t get it to pair?
I am thinking the second sensor is bad? Or the first tire is not truly paired. The horn honks once so that is supposed to signal a successful pairing.
one video I saw said to hit the brake 3 times then the ignition.
any wisdom and help is welcome
thanks
Old Jul 3, 2022 | 11:50 PM
HRTKD's Avatar
HRTKD
If the first time did pair and the second won't then it could be a bad sensor. Try pairing any other sensor as a work around.
Old Jul 4, 2022 | 04:50 AM
Fowlthing's Avatar
Fowlthing
I can’t get it to offer me another tire to try to pair. Seems it forces a specific sequence or progression in which tire to pair.
Maybe I am not hitting the correct button?
Old Jul 4, 2022 | 09:03 AM
HRTKD's Avatar
HRTKD
Just because it WANTS the next sensor in the series doesn't mean you can't pick another one. It has no idea which one is which until you do the relearn process. It shows tire positions on the screen, but if you moved the trailer tires around the PSI would follow the tire to the new position.
The truck understands the position that a sensor is at on the truck. The trailer TPMS system isn't as smart.
Old Jul 4, 2022 | 11:17 AM
Fowlthing's Avatar
Fowlthing
Thanks. I was being a little slow there...you are correct...I did that and it is the only sensor that will not pair. I have a bad sensor.
Thanks for your help.
Grant
Old Jul 4, 2022 | 11:22 AM
HRTKD's Avatar
HRTKD
Grant
As far as I know, any 433 mhz sensor will work, as long as it fits.
F250xlt2005
2009 - 2014 F150
Dec 7, 2011 03:05 PM
Just Chuck
All Things Towing
Apr 27, 2004 03:36 PM
