Determining max towing capacity
Old Sep 28, 2021 | 10:36 AM
chuckh1958's Avatar
chuckh1958
I used the VIN lookup on this site but when I check the max trailering wt I get 5 difference numbers for my VIN. How do I know which to use? I will be using a blue-ox WDH to tow a conventional trailer. FWIW the truck is a 2016 F150 XLT super cab with the 5.0L engine.
Wt Distributing Hitch - Max Trailer Wt: 10900, 9000, 7200, 8200, 8600 lbs 7200.0 min 11700.0 max
Old Sep 28, 2021 | 01:03 PM
seventyseven250's Avatar
seventyseven250
There is NO vin lookup tool that can accurately tell you the tow rating of your truck.
Best bet is to dig into the "ford fleet tow guide" for your specific model year. You'll often need to know the option packages and axle ratio in addition to stuff like engine and wheelbase.
Old Sep 28, 2021 | 04:32 PM
Old and soft's Avatar
Old and soft
Should be a sticker in your door jam that list ccc, cargo carrying capacity. A lot of vehicles run out of ccc before they hit max trailer weight. You, passengers, cargo, whd hitch, trailer tongue wieght all count towards your ccc.
Old Sep 29, 2021 | 07:18 AM
chuckh1958's Avatar
chuckh1958
Max payload on the sticker is 2011 pounds. I 'm trying to find out why the max trailer weight on the lookup tool shows so many numbers and which one applies to me. Either way I guess I'm ok because even the lowest # is more than my trailer weight will be fully loaded. When I bought the truck (used) from a Ford dealer they told me the max trailer weight was 10,500. I just wanted to double check but I don't see that number anywhere in the list
Bonus question - How is an F150 considered a "half ton" truck when the max payload on the sticker is 2011 pounds? Its been a while since I checked, but last time I looked a ton was 2000 pounds. Are they allowing 1011 pounds for passengers and fuel?
Old Sep 29, 2021 | 05:14 PM
Johnny Paycheck's Avatar
Johnny Paycheck
The lookup tool gives you the available ranges for an F150, not only yours. So, there’s nothing overly useful about them.
As for why 1/2-tons have more payload, thank technology. Back in the olden days, that may have been a pretty accurate number with mostly regular cabs running the roads and lesser drivetrains in them, to boot. The designation has just carried over. Seriously, the right 1-ton may have 7,000# or so for a payload rating these days.
Old Nov 1, 2021 | 03:01 PM
Schifference's Avatar
Schifference
I have been looking into the legalities of towing lately and some of it is confusing. With that said one thing you had best check on is the stated weight on your registration. I have read that some people purchase a brand new truck and the dealer provides that plates. Then the owner finds out that the truck is registered at a weight that is less than the truck weighs. It could be a citation waiting to happen.
Old Nov 2, 2021 | 02:37 PM
CGMKCM's Avatar
CGMKCM
2016 Trailer Life Towing Guide
Old Nov 8, 2021 | 12:56 PM
Jakerichards1's Avatar
Jakerichards1
It really is a towing guideline. Because not all trailers are designed the same. I will tell you that a really tall RV or box trailer will pull much heavier feeling than a couple pallets of concrete blocks on a flatbed due to wind resistance. Payload, axle rating, hitch rating, weight distribution hitch, are all much more important In determining a safe and legally acceptable trailer and truck combination. Why don’t you tell us what you are trying to pull.? Where do you wanna pull it? What kind of hills? How often?
Old Nov 11, 2021 | 03:14 PM
crewzer's Avatar
crewzer
Lightbulb
Here’s a link to Ford’s 2016 Tow Guide. Make sure you find the info for your particular truck configuration, and also read *all* of the fine print, disclaimers, notes, ifs, ands, buts and all other boring but important stuff.
Note the max trailer weight specs are for low trim levels, minimal options, a couple of skinny passengers, a lightly loaded truck, and ideal operations conditions. Increasing the trim level, adding options, realistic adult passenger size and count, heavily loading the truck, and operating under less conditions (i.e., at high elevation) reduces the maximum trailer weight specs.
https://www.fleet.ford.com/content/d...VTTowGuide.pdf
HTH,
Jim / crewzer
Old Nov 23, 2021 | 05:59 AM
GM in a Ford's Avatar
GM in a Ford
To make things worse, there are all kinds of weight ratings you "should" look at beside the max towing. Your truck and trailer tires and axles have individual weight ratings as well. Then you have GVWR and GCWR which will be less than the truck and trailer ratings. For instance, my F250 has a GVWR of 10,000 lbs and a max tow rating of 12,500 lbs for a total of 22,500 lbs. But the actual GCWR is 19,500 lbs. Then you have the hitch rating with and without WDH. Look up videos on YouTube for how to weight at a CAT scale. You take 3 passes over the scales to get the full picture.
Old Nov 23, 2021 | 07:08 AM
Desert Don's Avatar
Desert Don
Tow what you want, do not exceed tire and axle ratings for GVW on all vehicles…….towed and power unit.
Then see if you can pass the Wyoming requiremsnt………..stop in 40 feet or less at 20 MPH.
tjanderson60
2015 + Expedition & Navigator
Oct 29, 2020 09:43 PM
JMahun
2015 - 2020 F150
Nov 18, 2019 09:18 AM
Frank771
All Things Towing
Apr 14, 2017 12:08 PM
RedRaiderFan
All Things Towing
Sep 13, 2015 09:18 PM
lb27312
Aug 25, 2014 10:06 AM
