Rough takeoff
Old Sep 25, 2021 | 05:58 PM
Gorebs9589's Avatar
Gorebs9589
Rough takeoff
I attached a video but when I give the truck just a little gas it shakes and is very rough. I do it twice in the video to show the shaking. But if you give it a lot of gas taking off it is smooth. That’s the last one in the video. Please excuse the 2 year old talking in the beginning. Any ideas on where to start looking?
Old Sep 25, 2021 | 06:01 PM
Franklin2's Avatar
Franklin2
I would adjust the idle mixture screw or screws in the carb as a start. I say screws or screw, ,not sure what you are working on.
Old Sep 25, 2021 | 06:03 PM
Gorebs9589's Avatar
Gorebs9589
I tried to attach the video but it didn’t work. And I don’t know what I’m doing lol. It’s an 86 302 efi.
Old Sep 25, 2021 | 06:10 PM
Franklin2's Avatar
Franklin2
Have you pulled the codes on it? You may have a TPS code. If you don't, you could still check the TPS and see if it's working smooth with a old time meter.
Old Sep 25, 2021 | 06:31 PM
FuzzFace2's Avatar
FuzzFace2
Stick or auto transmission?
Dave ----
Old Sep 25, 2021 | 06:47 PM
Gorebs9589's Avatar
Gorebs9589
Dave ----
AOD transmission. 4wd if that matters.
Old Sep 25, 2021 | 06:56 PM
FuzzFace2's Avatar
FuzzFace2
Check the trans & motor mounts.
If the trans mount is bad it can move around and cause issues.
When you give it a lot of throttle the trans is held tight then.
Dave ----
Jrock909
May 19, 2003 05:14 PM
kelsey
Dec 23, 2002 08:56 AM
kelsey
Dec 22, 2002 01:22 PM
86motrhead
Sep 15, 2002 06:41 PM
stone
Jan 15, 2001 06:01 PM
