Grinding and knocking after level install.
Old Sep 24, 2021 | 04:41 PM
Etiennegreen's Avatar
Etiennegreen
Hi.
I recently got a 2.5 inch level, 17 inch wheels with - 12 offset to replace the original 18s. Had it all done at a shop.
I Randomly get grinding and terrible metal knocking. Once I engage the 4x4 the noises stop right away.
Taken it back a few times, they replaced the hub accuator and checked everything but keeps coming back.
Any insight?. I don't want to put all the original stuff back on becauae the truck looks awesome and I just spent 3000 on this work.
Old Sep 25, 2021 | 09:19 AM
jake415's Avatar
jake415
All IWE vacuum lines are in good condition and connected?
Old Sep 25, 2021 | 10:29 AM
JKBrad's Avatar
JKBrad
Welcome to FTE, Etiennegreen, We're glad you chose our site!
They must have damaged the IWEs (integrated wheel ends) which are your hubs that engage the front axle. The level it self won't cause that, as many of us here have one. Did yo use reputable shop with a good customer service track record?
Why the -12 wheels? Do they rub when you turn?
Old Sep 25, 2021 | 03:25 PM
jr105's Avatar
jr105
They may have damaged one of the vacuum lines to the IWEs.
Old Sep 25, 2021 | 03:26 PM
JKBrad's Avatar
JKBrad
Or damaged an IWE, depending on how they chose to remove and re-install the shock.
Old Sep 25, 2021 | 05:13 PM
Etiennegreen
I noticed my passenger side line was not connected to the hub. Put it back in and tried to replicate the symptoms and didn't get the noise again... Fingers crossed that's all it was.
Old Sep 25, 2021 | 05:23 PM
Etiennegreen
I
I went to OK Tire, which is a well known chain in canada. we've taken other vehicles there and have largely been well taken care of. They haven't charged me for looking into the noise, and replaced the driver side hub actuator after i complained about the noise the second time free of charge. Today i found the passenger side vacuum line disconnected... perhaps everybody, including the shop just focused on the driverside since that is where the noise seemed to come from. i guess its possible it was always disconnected and nobody noticed? is it possible for the level and wheel setup to be adding stress to the vacuum line and popping it off ?
I reconnected the vacuum on the passenger side this morning and haven't heard the noise today.
thanks for replying, much appreciated.
Old Sep 25, 2021 | 07:24 PM
jake415's Avatar
jake415
I had the same experience. The tech left my passenger side vacuum line off. Seems like a common error for some reason...
Old Sep 25, 2021 | 08:38 PM
JKBrad's Avatar
JKBrad
Sounds like the fix was simple, which is good. Now post some pics of your truck!
Old Sep 26, 2021 | 04:10 PM
Etiennegreen
Unfortunately the noise came back today and all lines were connected.
Passenger side looked like it might have been kinked or bent at sharp angle.. maybe that could cause the vaccun to fluctuate? Not sure any idea. ?
Old Sep 26, 2021 | 05:52 PM
JKBrad's Avatar
JKBrad
There could be a pin hole caused by the kink
skidoorulz
16
Jun 19, 2021 04:24 PM
emitt
Mar 14, 2021 09:10 AM
EpicCowlick
Nov 4, 2017 09:12 PM
FordBoy2012
1997 - 2003 F150
Aug 31, 2013 10:46 PM
kandcrod
May 23, 2002 08:45 PM
