Refinished Heater Box
Old Sep 22, 2021 | 11:09 PM
crazy96863's Avatar
crazy96863
I refinished my heater box. Pretty happy with the way it turned out. Still need to get a new blower and core but that’s the easy part. This thing was time consuming. I did a full disassembly and using the metal parts from my California truck and the plastic pieces from a New England donor, I made a box that’s about as close to new as I’m ever going to get. Hopefully good for another 50 years.
Old Sep 22, 2021 | 11:11 PM
crazy96863's Avatar
crazy96863
Aside from cleaning, I didn’t refinish the inside of the box. I did refinish the flaps using black rtv to reattach the foam where it was needed.
Old Sep 22, 2021 | 11:15 PM
crazy96863's Avatar
crazy96863
If anyone is wondering, this stuff is great for plastic adhesion. It really wasn’t needed as most of this box gets very little exposure but there was a light amount of dry rot on the surface so after cleaning that off I figured some UV protection was in order just for good measure. If I didn’t know it was on there I don’t think I would guess this was painted.
Old Sep 22, 2021 | 11:19 PM
tbear853's Avatar
tbear853
Great job there!
I often wish now that I had kept mine ... but there's been times in some many years past I felt otherwise.
Old Sep 27, 2021 | 08:51 AM
Jack250's Avatar
Jack250
Looks great. Do you mind measuring the hole for the resistor? Mine was blown out in that area. I repaired it with fiberglass this weekend and have to recut the hole.
Old Sep 27, 2021 | 08:37 PM
crazy96863's Avatar
crazy96863
1-1/16” x 2-3/8”
Old Sep 27, 2021 | 08:39 PM
crazy96863's Avatar
crazy96863
It’s worth noting where the diagonal provision is to ensure the resistor is installed with the correct orientation.
Old Sep 27, 2021 | 08:42 PM
crazy96863's Avatar
crazy96863
If anyone could explain what the resistor does here I’d appreciate it. Considering the manual controls of all this I’m at a bit of a loss here. That said I’m sure it does something or they wouldn’t have put it in there.
Old Sep 27, 2021 | 09:14 PM
redroad's Avatar
redroad
The resistor controls all speeds (except high) of the heater blower by limiting each speed by a measured coil which limits by "resisting" the current so a certain rpm is achieved for the fan. The resistor block is placed in the heater box so whatever fan speed is chosen that coil is cooled by the air that flows through the box. Each coil produces heat as it does it's job to resist. The filament of an old school light bulb is a resistor of sorts.
Old Sep 28, 2021 | 07:46 AM
Jack250's Avatar
Jack250
Thank you sir!
F-ONE
Aug 19, 2019 11:24 AM
aj64f100390-292
Sep 18, 2018 11:26 AM
robert_l_ross
Garage & Workshop
Apr 28, 2017 09:35 PM
fordf348
May 20, 2014 05:14 PM
martin72
75
Dec 25, 2013 10:37 PM
