Lean mixture plugs
Old Sep 22, 2021 | 07:46 PM
sixpotfordaholic's Avatar
sixpotfordaholic
Lean mixture plugs
My first post...e150 van inline six e f I .. friend passed on van to me . 150,000 miles. Has an ongoing problem. Thousands spent on services and parts. Still there... plugs from last service.. white ash on one side of electrode. Very little tan colour anywhere all plugs same .. insulator heat spotting on some plugs..looks like it’s firing off the side of plugs and not electrode tips.
my limited knowledge thoughts. Could it be
timing train components worn
injectors need cleaning
mas flow air sensor
manifold air sensor
tps sensor
engine control module ..ecu
fuel pump pressure sensor
seems like it’s missfiring when cruising. Not under load
almost when the transmission wants to change 2nd to third. It’s an overdrive type transmission
could the torque converter be a problem.. . Lots thoughts I know.
Old Sep 24, 2021 | 06:51 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
Being the truck is EFI it has a computer so the first thing to do is pull codes.
BTW what year are you working on?
Dave ----
Old Sep 24, 2021 | 07:29 PM
sixpotfordaholic
Ford e150 club wagon 4.9
there are no faults showing on obd 1 tester..which further mystifies things.
its apparently had this stuttering problem from very early on, but gets progressively worse now..
I will get into more soon.
guess to order an ecu . Throttle position sensor.02 sensor.. and any other sender associated with this motor. Try to get someone to stethoscope the timing chain adjuster. Or get into the timing chain and replace components.
at some point every single part associated with this problem will be replaced.
fortunately the previous owner has already spent a couple of grand. With parts replacer mechanical shops.
I’ll stick with to the end.thanjs for reply. Maybe I should post pics of the plug.
Old Sep 24, 2021 | 08:20 PM
FuzzFace2's Avatar
FuzzFace2
Some of the code readers dont work, show codes but there is another way to pull them but I dont know how or where it shows with blinking light.
Before buying all them parts get the motor up to temp and disconnect each part and see if you get a code and if your reader will show it.
That would prove if your reader can read or not.
As for the timing chain look into it more as the 300 dose not use a chain but gears.
Now you can check for play that I dont think they will have by pulling the dist. cap and looking at the rotor.
When looking at the rotor turn the crank till the rotor just starts to move then turn the crank the other direction till the rotor just starts to move.
Measure the movement of the crank in degrees and let us know what that is, it should not be much.
Have you done a compression test and a leak down test so you know if the motor is in good shape?
If the motor its self is not any good then what ever makes it run will not have much luck doing its job.
Dave ----
Splace03
Jun 10, 2021 01:59 PM
na5rc
1997 - 2003 F150
16
Oct 6, 2020 09:03 PM
'88 E-350
Oct 20, 2017 12:31 AM
keifer59
1983 - 2012 Ranger & B-Series
Jul 15, 2009 09:21 AM
AQUARIES1
13
Mar 1, 2004 06:49 AM
