3rd gen towing math help
Seems weird that I can only tow 2k with the van empty, fill it up with 2k worth of linebackers and still tow the same 2k.
Wondering if I can safely tow my buddy's 5300 travel trailer. His Ram died and last week he towed it 120 miles with his 2019 VW Tiguan 4 cylinder! (Rated at 2300lbs towing!). We live in FL FWIW.
Thanks in advance! Axle code is 33 which is the Dana 61 3.54.
You need the aproriate reciever. If your van didnt come with one the limited tow capacity is due to actually using the bumper to connect the ball.
I mounted a class 4 reciever on mine and if i recall correct that gave me a tow cap of 10k and max tongue weight of 2k. You would need to check for yourself but if i understand correctly you would need a class3 reciever to safely tow your friends camper.
Yout truck as it stands now is not safe to tow more than 2000lbs and the main reason for that is the lack of a reciever and brake controller, if both of those are added you move to the higher ratings where the limiting factors become the weight of the vehicles and the trailers frontal area.
GCWR is like GVWR, your current weight is factored into both so those 2k linebackers would negate some of your trailer towing weight.
I'd assume the extra 18 inches past the rear axle of your club wagon isn't helping the tow rating either.
With a weight distributing hitch you may be able to tow that trailer, keeping an eye on axle weights.
The unfortunate reality is vans aren't the best for towing.
Ok, so not the best simile but do you get what I'm saying?
I'd debate vans are way better than trucks all day for a lot of things. Trucks are usually rated to move bigger weights due to the difference in curb weight compared to a van.
Example: 1996 F250 and E250with a 5.8 and similar gears have the same GCWR (13,000lbs) but the truck is rated for 7900lb. trailer vs van at 7600lb.
Not a big difference but the trucks offer trailer ratings up to 12.5k with the right engine and gears without getting into diesels or dually. Vans only get up to 10k.
Reguardless, both '96 manuals say:
Super Cooling is required with trailers over 2,000 lb (907 kg).
Super Cooling and Handling/Suspension Package or trailer towing package is required with trailers over 3,500 lb (1587 kg).
I haul a lot of scrap metal and vehicles. Like I said my trailer is 2,200 pounds empty. And when I'm towing it's not empty very often.
Example: .........................................
Each type vehicle have their uses, if they didn't one of them would have long, long ago faded into oblivion. Either when properly equipped will haul OR tow amazingly heavy loads in a safe manner. In the end its the owner or user who is in the best position to determine which suits their needs. As a tradesman vans excel due their enclosed cargo space---there's simply no better tool-box-on-wheels I've ever seen. If an F-Series met my needs and requirements I'd have on in place of or addition to my current E-Series.
IF I need to haul loads my E-Series could not be configured to safely handle it'd be a F-Series---simple as that.
