Creaking Drivers Door
Old Sep 21, 2021 | 02:19 PM
Rob89's Avatar
Rob89
My drivers side door is creaking badly. I’ve tried wd40 and white lithium grease. No luck. I looked at it closely today and it looks like the entire door sill that the hinges are connected to is flexing…right in the middle (vertically) where there is a piece that goes in and out of the door as you open/close.
Anyone else experience anything like this? I’ll try to get a video of it later.
Old Sep 21, 2021 | 02:40 PM
Beast2.0's Avatar
Beast2.0
Creaking as you open/close the door or when driving down the road? I have seen some that said they had to tighten the hinge bolts and that helped with the noise. Or the electrical tape around the door strike.
Old Sep 21, 2021 | 02:59 PM
mitch8628's Avatar
mitch8628
On my 2006 I've had to replace the black shaft looking piece that is about the middle of the door - twice. Fixes it every time.
It is called a Door Check. I got a Dorman Replacement on Amazon:
Amazon.com: Dorman 924-152 Door Check for Select Ford Models : Automotive Amazon.com: Dorman 924-152 Door Check for Select Ford Models : Automotive
. Not sure if it works for newer trucks, but this was the one that fit my 06.
Old Sep 21, 2021 | 03:08 PM
C12H24's Avatar
C12H24
It's under warranty. Something is obviously wrong. The pillar section is not supposed to flex. I know most people absolutely loath having to take a vehicle in for service, but you don't have a choice here. That flexing will lead to cracking and a tear out. It seems something is missing from the cab construction and that too is a safety issue.
Rob89's Avatar
Rob89
Creaking while opening and closing, not while driving.
Old Sep 21, 2021 | 04:18 PM
Louisville Joe's Avatar
Louisville Joe
Flexing is normal, aluminum cab.
Old Sep 21, 2021 | 05:41 PM
Rob89's Avatar
Rob89
Turns out there is a TSB for this. Door(s) Noisy When Opening And Closing – Door Check Arm Cleaning And Neutralization
20-2235
Old Jun 4, 2024 | 01:12 PM
WXboy's Avatar
WXboy
Mine was horrible. Couldn't stand it anymore. Bought both front door checks for $30 delivered and installed them this past weekend. Takes 10 minutes per door. Electric ratchet, short extension, 7mm and 10mm sockets, small pick, and plastic door trim tool are all I used. Honestly was pretty easy to do. Both doors are dead silent now.
Psyclopse
Mar 25, 2012 11:49 AM
neilc88
Aug 9, 2006 01:06 PM
joemajesty
Dec 18, 2003 12:52 PM
