2019 F250 clicking noise when shifting under load
Old 09-21-2021, 12:53 AM
hodgesjl's Avatar
hodgesjl
hodgesjl is offline
My 6.7 power stroke clicks when shifting under load. It started out only doing it when shifting from first to second but has now progressed to second to third. It is only when I’m towing long distances and doesn’t do it initially. Takes a while to start doing it. It feels and sounds like it’s under the drivers feet. Doesn’t do it when I’m not pulling anything. Hope this description is clear enough to get some advice on this. It’s a 2019 6.7 with 6000 miles on it. Yes only 6000. Any help would be appreciated.
Old 09-21-2021, 07:51 AM
Fefanatic's Avatar
Fefanatic
Fefanatic is offline
Check carrier bearing on driveshaft to be sure bolts are tight and it's seated in the rubber collar correctly. Is your truck four wheel drive?
Old 09-21-2021, 12:02 PM
hodgesjl's Avatar
hodgesjl
hodgesjl is offline
Yes it is 4 wheel drive.
Old 09-25-2021, 09:17 AM
Fefanatic's Avatar
Fefanatic
Check all engine and transmission mounts. I doubt it's your transmission. It sounds like something is moving too far under load.
Old 11-10-2021, 11:52 AM
Squan320's Avatar
Squan320
Squan320 is offline
4th Gear
Towing my RV I get a short 'grind' kind of noise between 3rd and 4th gear.....only under load, and only after a while....took to Ford, no codes, nada. In reading above what should I "torque" to when I start tightening things?
Old 02-09-2022, 03:23 AM
hodgesjl's Avatar
hodgesjl
hodgesjl is offline
Did you ever get it figured out? I am having the same issue with my truck.
Thanks
Old 02-09-2022, 07:24 AM
Pugga's Avatar
Pugga
Pugga is offline
Thanks
You just quoted your own post so I'm going to go out on a limb and say that guy didn't sort it out yet...
Nate Sabo
09-30-2015 01:03 PM
99 5.4
1997 - 2003 F150
01-03-2010 09:25 AM
rgrp944
1999 to 2016 Super Duty
02-23-2007 07:28 AM
Phitty
1983 - 2012 Ranger & B-Series
07-20-2005 01:48 PM
Quick Reply: 2019 F250 clicking noise when shifting under load
