Wire location....
Old Sep 20, 2021 | 09:22 PM
Restenhaus72's Avatar
Restenhaus72
Wire location....
Recently picked up a '73 F100 (390/C6/2wd) & going thru cleaning up & sorting out some of the electrical wiring in engine compartment. The original wiring is pretty intact & in fairly good shape overall but I found one wire (yellow/green tracer) that was cut & is just dangling to the side (see wire with red arrow). Does anyone know where the other
end of that wire attaches to ? I can tell you the wire next to it (green w/red tracer) goes to the "I" terminal on my voltage regulator. At the other side of the connector that yellow w/green tracer wire goes to the horn relay & the green w/red tracer wire goes along back fire wall, then into cab, & finally connecting to harness for instrument cluster (probably for Alt light indicator).
Any help would be greatly appreciated !
Old Sep 20, 2021 | 10:05 PM
redroad's Avatar
redroad
Old Sep 21, 2021 | 06:55 AM
Meridian_Mike's Avatar
Meridian_Mike
Just a shot in the dark here.....
BUT.... look at #14401 in the diagram. It points in 3 places (first), to that plug then on to the harness that goes out to the lights.
AND there is another 14401 pointing to the horn like Redroad said.
Old Sep 21, 2021 | 08:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yellow with green trace goes from the horn relay to the horn(s).
Old Sep 21, 2021 | 11:38 AM
Restenhaus72
Thanks gents. That would explain things. I am missing one of my horns which likely has the connector that marries to that loose wire.
Old Sep 22, 2021 | 08:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
A single horn was standard, two was an option. In '73 the single horn was mounted to the right of the radiator, above the voltage regulator. When you had dual horns the second was mounted to the left of the radiator in about the same location. The wire for the second horn "y"d off of the connector at the first horn and ran across the top of the radiator core support.
Also, the two horns were different, one was high pitch, the other low.
MNDuck
Electrical Systems/Wiring
Jul 3, 2019 06:59 PM
fordtough81
Aug 22, 2013 06:40 PM
dgrant09
Mar 2, 2008 09:03 PM
RES94025
Jul 17, 2005 02:15 PM
Earl
Sep 29, 2002 09:03 AM
