Help, I've been a bonehead!!!
Old Nov 2, 2003 | 02:29 PM
rpickle's Avatar
rpickle
Pulled the Distributor w/o marking
Well, I tried the swap from the TFI ignition to the DurasparkII today. I got the distributor, harness and Duraspark module from a truck from the junkyard. I cleaned it all up. I pulled the distributor from my truck, read the manuals AFTER to see what alignment marks I should look for, but I found out I was supposed to make my own marks! Yikes.... I put the "new" one in where I thought it should go, guess what, duh, it won't start. Any help in trying to get that in the right spot would be GREAT.
Thanks...
Rick R.
Old Nov 3, 2003 | 07:57 PM
ob-4-id's Avatar
ob-4-id
find compression stroke on no.1 cyl, line up dist on no.1 plug tower, drop it in and hope your not 180 out.
Old Nov 3, 2003 | 10:11 PM
rpickle's Avatar
rpickle
Thanks a lot. I hope to give this a try in the morning after work.
Rick
Old Nov 4, 2003 | 10:06 PM
rpickle's Avatar
rpickle
I attempted this. I belive I had it correct the first time. Engine ran smooth, but wouldn't idle. When I shot it with the timing light, it ran best when the timing was way before TDC, off the scale. When I adjusted it up, the engine really ran bad. Thought maybe I had the distributor in wrong, so I tried it again. Nope, I think it was correct the first time. Was getting to be bedtime, so I quit for the day. What would have caused the timing to be so off the mark?
Thanks.
Rick
Old Nov 5, 2003 | 10:34 PM
rpickle's Avatar
rpickle
Hey! I got it all straightened out. Helps to have all of the vacuum ports plugged! Timed out pretty well. Anxious to run a tank of fuel thru it to see if I get better than 11mpg....
Thanks for the help folks.
Rick
Old Nov 5, 2003 | 10:37 PM
ob-4-id's Avatar
ob-4-id
good deal rick, glad it worked out for you.
Old Nov 8, 2003 | 04:46 PM
jmasterv's Avatar
jmasterv
yeah rick...those vacuum lines are pretty critical...oh well...****** happens...congrats bro
