Heavy Duty Leaf Sprin Replacement
Old Sep 17, 2021 | 03:01 PM
jerryparks's Avatar
jerryparks
Hey all
I have a '97 F-250HD with a utility body. The body has some weight to it, the truck is 24 years old and time hasn't been kind to my leaf springs, which look like pieces of flat bar holding my axle at this point.
I'm considering swapping out my factory leaves for a set of Dayton 43701HD Springs (rated at 4295 lbs). Its a 7 leaf pack, 3.5" thick. Are there any other parts I should look into replacing at the same time? I just replaced my front and rear shocks, and noticed improved ride quality, but my rear tires are still sitting up in the wheel wells.
Is this a job I can easily do in my driveway? I've never done leaf springs before and any advice would be appreciated.
Old Sep 17, 2021 | 03:03 PM
SFaulken's Avatar
SFaulken
Yes, it can be done in your driveway with a floor jack and some jackstands.
Old Sep 17, 2021 | 03:36 PM
JJF20's Avatar
JJF20
I'd call one of the spring suppliers, or a local spring shop and ask about it. I'd suggest all new hardware and shackles on hand when you do it, save the hassle of trying to change out bushings in the driveway. Look at the hangars while you're there. A good spring shop like ATS can ship you everything, including the hardware, shackles, hangars, u bolts etc.
Old Sep 17, 2021 | 03:47 PM
TB250's Avatar
TB250
Back in the olden days, Southwest Wheel in Dallas, used to "re-curve" leaf springs. They essentially arched the springs in a special tool and ran them through the heattreat process. At the time, it was a lot less expensive than new springs. However, I suspect in today's labor rich, throwaway society, that is no longer the case.
Old Sep 17, 2021 | 03:52 PM
SFaulken's Avatar
SFaulken
It's darn near impossible to find a company that will re-arch springs anymore. And if you do find a company that isn't local, the shipping costs, in general, will put you well over the price of just buying replacement springs.
Old Sep 17, 2021 | 06:47 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Being “down south” it might not be too bad. I have found the worst part is removing the bolts. On the F-150 and Bronco II, I had to cut the spring eye bolts to get them out.
Lrrr-RulerOfOmicronP
24
Nov 25, 2021 10:30 AM
tr0y
Jan 13, 2021 07:07 PM
Zinger351m
Aug 27, 2020 09:45 PM
greenstar
Jun 13, 2014 08:12 PM
89MustangGX
May 11, 2004 09:21 PM
