Found it!
Old Sep 17, 2021 | 09:25 AM
Ford Firefighter's Avatar
Ford Firefighter
Found it!
96 f350 CC LB DRW ZF5
I had almost complete loss of power, took 2 miles to get up to 55mph, stuttering but no smoke black or white.. Took the air box off, no dice. I checked thru the entire fuel system, tank to engine and the only thing I found was the M-fuel pump was leaking, so I swapped it out for a new one and still the same thing. Turned out the EBPV was stuck closed, now this is a completely stock truck… including the exhaust so the jet engine was unnoticeable unless you had your ear in the tailpipe!
Took a crow bar, opened it up and she flew like a scolded dog! Hadn’t felt that in a while!
I figure a problem solved here is just as good as a problem unsolved! Lol
Man I love this forum!!
Old Sep 17, 2021 | 06:58 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Wow good deal. I wonder if thats the problem I have. The EBPV is the the flapper inside the exhaust side of the turbo? Maybe fine is stuck somewhere in between. Im only getting 5 PSI when i stomp on it.
Old Sep 17, 2021 | 07:27 PM
seijirou's Avatar
seijirou
In mine you can hear it cycle right after start up.
Old Sep 17, 2021 | 07:30 PM
Hit Man X's Avatar
Hit Man X
In mine, it has been removed.
Old Sep 17, 2021 | 08:14 PM
seijirou's Avatar
seijirou
If you want to come over and turn wrenches there's no need to be coy, you can just ask
Old Sep 17, 2021 | 10:08 PM
Hit Man X's Avatar
Hit Man X
Too hot now, this winter we can screw around. @BBslider001 is down so is @gtex
I am in FTW area.
Old Sep 17, 2021 | 10:45 PM
seijirou's Avatar
seijirou
I am in FTW area.
I'm down. Assuming I have this thing going down the road by then, or there's plenty of space where I'm at too. Just a little east of DFW.
Old Sep 18, 2021 | 05:06 AM
Ford Firefighter
Next step is remove it, but if I’m going to put all that work into the turbo I might as well rebuild the turbo with a 360 bearing, and maybe a wicked wheel or something, and might as well do bellowed up-pipes and plenum inserts and… yeah, that’s how it goes I guess!
Old Sep 18, 2021 | 07:29 PM
Hit Man X's Avatar
Hit Man X
Three 12 point fasteners. I think they were 8mm heads. Pull it, saw off the actuator arm. Freeze plug in the adapter. Done.
Old Sep 19, 2021 | 07:40 AM
Ford Firefighter
So you don’t have to weld anything?
Everyone makes a big deal out of cutting it out and welding it.. if it’s that simple I’ll do it like you said!
Old Sep 19, 2021 | 01:00 PM
z31freakify's Avatar
z31freakify
You can also use a carriage style bolt, if for what ever reason you can't find a freeze plug locally.
Old Sep 19, 2021 | 01:01 PM
Ford Firefighter
Do you put a little sealant on it or anything?
Old Sep 19, 2021 | 01:06 PM
Ford Firefighter
I kinda just wanna tell my wife that it’s broken and this is what you need to fix it…
https://obssolutions.net/products/ob...37789259989186
Plus the turbo! 🤣
Old Sep 19, 2021 | 01:10 PM
seijirou's Avatar
seijirou
Could a person leave the shaft alone and just take the plate off?
Old Sep 19, 2021 | 02:33 PM
Ford Firefighter
I don’t see why not, tho the whole thing is prone to oil leaks so I think that’s the main reason people get rid of them but if it’s not leaking yet then cutting the butterfly out and leaving the shaft should work just fine
