Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Engine Light, Vibrating Gas Pedal
Old Sep 16, 2021 | 10:42 AM
xenophone's Avatar
xenophone
2008 Escape LTD V6
My Check Engine light came on yesterday. At the same time, I started to notice some weird behavior when accelerating, mostly from a dead stop in lower gears. There is a vibration in the gas pedal. The throttle/acceleration also felt a bit less responsive, but it's hard to say. When I got home I popped the hood with the engine running, and there is an intermittent sucking/air noise, coming from somewhere near the drivers side of the engine block. I couldn't identify exactly where the sound is coming from, maybe something buried further in.
Any ideas?
Old Sep 17, 2021 | 08:36 AM
scott91370's Avatar
scott91370
Go to a local auto parts store and get the code(s) read - this will give you the best starting point.
Old Sep 20, 2021 | 11:46 AM
xenophone's Avatar
xenophone
It's a cylinder misfire. Hopefully nothing too serious. Thanks
Old Sep 26, 2021 | 09:00 AM
DBGrif91's Avatar
DBGrif91
Inspect the air intake boot, PCV and vacuum hoses, and intake for tears or cracks to identify the noise; however if you don’t seem to find anything, it could just be the air moving though the air box.
Old Sep 26, 2021 | 10:56 AM
tomw's Avatar
tomw
There was a problem with backfire blowing up the intake manifold. Truly.
I would check the EGR valve and the diaphragm that opens it. The PCV valve is also on the drivers side of the engine and could also cause a vacuum leak. Get a good bright light and shine it back in that area. I bet you can find the problem visually.
tom
Old Sep 29, 2021 | 12:33 PM
xenophone's Avatar
xenophone
The acceleration issues and check engine light were caused by a cylinder misfire. It was just a bad coil, so this is fixed now.
I actually haven't checked to see if it's still making the sucking noise, I assume it is and is unrelated to the misfire. But if this is a problem I should figure out what's going on. I'll look at it this weekend.
cer
Jan 29, 2016 03:58 PM
Brownie12
Nov 24, 2012 07:16 PM
Joshglov
Apr 6, 2010 08:34 PM
Finger mullet
Jan 3, 2008 11:36 AM
johnny1720
Apr 3, 2003 10:32 PM
