Zinc amounts?
Old Sep 16, 2021 | 09:41 AM
CB3's Avatar
CB3
Zinc amounts?
I am currently using Rotella 15w-40 diesel in my 1978 F-100, 302, for the zinc availability. As colder weather approaches I am considering switching to Rotella 10w-30 diesel.
My question is whether or not the zinc level is the same in this different weight?
Thanks for any information.
CB3
Old Sep 16, 2021 | 10:27 AM
77 HOS's Avatar
77 HOS
According to a quick google search they both say approx 1200ppm. Viscosity should be the only difference.
I run vavoline VR-1 10/30 currently.
Old Sep 16, 2021 | 12:01 PM
Flecker's Avatar
Flecker
Old Sep 16, 2021 | 02:18 PM
chappys4life's Avatar
chappys4life
I run 15w-40 t4 in my FE. I think about VR-1 sometimes and would have to go 20w-50 but I live in Texas so heat is more my issue.
Old Sep 17, 2021 | 04:43 PM
CB3's Avatar
CB3
zinc amount
Thanks for the comments!
CB3
Old Sep 17, 2021 | 09:20 PM
Christmas's Avatar
Christmas
I mix my own every 5k mi. 5.5qts of oil, 1 pint of zinc and 1 pint of stabilizer.
Old Sep 18, 2021 | 01:36 AM
76_78_06_FordTrucks's Avatar
76_78_06_FordTrucks
What ratio are you mixing this all up at and how long have you been using this mix in your truck?
Old Sep 18, 2021 | 01:49 AM
Christmas's Avatar
Christmas
The ratio is right there and I have done this for 30yrs plus in multiple vehicles. The Lucas oil stabilizer prevents wear on cold or sat for a few weeks starts. Zinc keeps the cam happy. Semi synthetic keeps the seals clean. I will never stop using this on an older motor.
Old Sep 18, 2021 | 01:54 AM
76_78_06_FordTrucks
Duh , I see it now. Thanks for the reply though.
Old Sep 18, 2021 | 08:29 AM
dustyroad's Avatar
dustyroad
Mobil 1 turbo diesel 5w-40 has enough zinc in it fwiw. I run it in my 86, my 79 engine is done and gets the cheapest oil in it.
you don't need to stick with rotella is all I'm pointing out, like the other posters have.
Old Sep 18, 2021 | 09:09 AM
yardbird's Avatar
yardbird
I've been running Delo 400 XLE in my Ford and Dodge for a couple of years now, and Rotella for many years before that. I chose to switch to Delo because their oil is formulated for gas and diesel engines, and has a SN rating. I mix 1 gallon of 10w30 and 1 gallon of 15w40 for the 8 quart Dodge, and 3 quarts of each for the 6 quart Ford.
That gives me a 12.5w-35 mixture. The engines run much smoother and quieter with this blend than ever before.
Mike F250
Sep 18, 2021 01:40 AM
Tecman
Mar 21, 2009 11:01 AM
jetch114
Jan 24, 2007 09:50 PM
00Lariatman
Jul 9, 2004 01:03 PM
FredsF250TD
Jun 27, 2004 10:21 PM
