Dead pcm
Old Sep 13, 2021 | 07:50 PM
lpzd's Avatar
lpzd
Dead pcm
Truck died going down the road pulling the camper , will not restart.
No wait to start light no call for fuel pump no connection to forscan
Fuse 30 for fuel bowl heater is good, heater has been unplugged for a long time.
This is looking like dead pcm to me, any ideas other that that before I order a replacement?
Old Sep 13, 2021 | 07:52 PM
z31freakify's Avatar
z31freakify
Check the chip and see if it didn't come loose.
Old Sep 13, 2021 | 07:53 PM
GregA's Avatar
GregA
Old Sep 13, 2021 | 08:01 PM
lpzd's Avatar
lpzd
Turned truck off pulled chip, still no response from pcm
Old Sep 13, 2021 | 08:03 PM
lpzd's Avatar
lpzd
Duplicate post
Old Sep 13, 2021 | 09:12 PM
BWST's Avatar
BWST
Got Data?
How is fuse #3 (Data link connector) and fuse #19 (PCM)?
Might also be caused by a sensor that is shorting VREF. Try unplugging the MAP sensor, the EBP Sensor, the ICP sensor, and see if you get the WTS back.
Old Sep 13, 2021 | 09:45 PM
udsuth78's Avatar
udsuth78
Are the relays for the pcm and idm engaging when key is turned on. It happens quick so you have to be touching the relay while turning the keyto run.
Old Sep 14, 2021 | 10:44 AM
lpzd's Avatar
lpzd
Power is present at all fuses, idm and pcm relays are clicking active as key is turned to run.
Old Sep 14, 2021 | 10:55 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If you have a multimeter and want to double check everything by back probing the PCM connector, check out the links below.
https://www.ford-trucks.com/forums/1...l#post20036473
and
https://www.ford-trucks.com/forums/1...l#post20036506
If you have what you are supposed to have there, you could check the PCM ground circuits at the PCM connector and if you have good grounds and 12v power, well the PCM may in fact be dead. At which point I would send it to Jonathan at Diesel Tech Chattanooga in the link provided by GregA above.
Old Sep 14, 2021 | 12:10 PM
lpzd's Avatar
lpzd
First thanks for all your input, second it does indeed look like I need a pcm. All tests on the 104 pin harness checkout. So time to ship it off.
Old Sep 14, 2021 | 12:51 PM
MD_7.three's Avatar
MD_7.three
Emphasis added.
A short to ground on the pigtail, or internally on any of these sensors can and will cause all the symptoms you are describing
Also included are the TPS, and CPS ... inspect the pigtails for chafing/exposed wires and disconnect 1x1 while turning the key to on, if you get your WTS light back you've found your bad sensor/pigtail ...
Old Sep 14, 2021 | 01:53 PM
Sous's Avatar
Sous
FTE Emeritus
As Josh mentioned above... Before sending the PCM off, maybe take just a bit more time and be 100% sure. I have attached the 5v reference pinpoint test from the PC/ED volume of the Ford Service Manual. It states "PCM breakout box", but you can usually work around this sort of specific test equipment.
More importantly, it names the sensors that are on the 5v reference circuit.
I have also pinned a wiring diagram from a 2002 that indicates the 5v reference circuit in color code.
Old Sep 20, 2021 | 04:17 PM
lpzd's Avatar
lpzd
Ended up borrowing my brother's truck to salvage my hunt. After going over every sensor I could, verifying voltage coming into pcm harness I will be shipping my pcm out tomorrow.
Old Nov 11, 2021 | 12:32 PM
lpzd's Avatar
lpzd
IT'S ALIVE!!!
sort of, had to jump start the truck but now it's not charging pulled alternator had it tested that's not the issue.
going to take break head back out after lunch.
Old Nov 11, 2021 | 02:43 PM
lpzd's Avatar
lpzd
OK for real this time, it's all back together.
