Replacement cowl and firewall for '75 Highboy
Old Sep 12, 2021 | 03:44 PM
ArtWebb's Avatar
ArtWebb
Howdy, all.
I'm new to FTE and looking for a little firewall guidance on my 1975 F250 Highboy. I've discovered that the seam where the firewall is welded to the underside of the cowl has rusted out. (It seems as if this is a fairly common problem with these trucks.) The rust is so bad that the firewall is nearly disconnected from the cowl. I've searched high and low for a new (or used) firewall and am coming up empty handed. Anybody have any suggestions where I might find a replacement firewall?
Many thanks in advance!!!
-Art
Old Sep 13, 2021 | 12:35 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Welcome to FTE, your best bet is to find someone with a parts cab in VA and go cut out what you need. I have 4 parts trucks/cabs, but I am in Missouri.
FTE has STATE chapters, here is Virginia's. https://www.ford-trucks.com/forums/forum147/
Old Sep 13, 2021 | 12:37 AM
77&79F250's Avatar
77&79F250
Opps double post.
Old Sep 13, 2021 | 07:22 AM
ArtWebb's Avatar
ArtWebb
77&79F250,
Thanks for the input! I'll definitely look into it. Just curious, where are you located in MO? I'm from a farm just outside of Columbia and get back to see family
occasionally. Might swing by and check out your parts trucks. Again, my sincere thanks!
Old Sep 13, 2021 | 08:02 AM
77&79F250's Avatar
77&79F250
Polk County area, 2.5 hrs S/W from Columbia. PM sent, ck your PM (private messages) inbox via your User CP (control panel) and or see the top R/H corner? See your user name and private message counter? Click on it to go there.
Old Sep 13, 2021 | 08:42 AM
jackietreehorn's Avatar
jackietreehorn
I know of 4 dents in yards near me in VA. One might even cut it out for you.
Old Sep 13, 2021 | 04:40 PM
ArtWebb's Avatar
ArtWebb
Awesome!
Do you mind sharing the names of those yards so that I may contact them?
Many thanks!!!
Old Sep 14, 2021 | 06:01 AM
Mark8man's Avatar
Mark8man
Have you fully accessed rust in the rest of the cab? Typically if the the cab is rusted that bad in the location you stated there will be terminal rust in other areas. Might be better in the long run to get another cab....or even in the short run. No small feat to weld in a new firewall.
Old Sep 14, 2021 | 08:31 AM
jackietreehorn
Pickapart in Stafford VA has one, another junkyard in Friendly MD has 3 and I recall a yard in Shenadoah called Richard’s that was full of them a few years back.
Old Sep 14, 2021 | 12:45 PM
ArtWebb's Avatar
ArtWebb
The truck is actually fairly rust free. Surprisingly enough.
Old Sep 18, 2021 | 11:37 AM
ArtWebb's Avatar
ArtWebb
That's awesome info! Thank you so much!!!
Old Sep 18, 2021 | 06:22 PM
5851a's Avatar
5851a
A cowl box replacement is a very big job, if you cannot find new replacement parts you get to cut the spotwelds X2. There is some kind of coating on cowl box that shouldn't be ground or welded without protection. Maybe Zinc, just guessing. Should be something in the search. My vote would be for same year or close cab swap, make sure the cab ventilation is the same system.
Old Sep 18, 2021 | 06:34 PM
ArtWebb's Avatar
ArtWebb
That's great info. Thank you!!
I've located a salvage yard that has several '73 - '79 F series trucks that I'm gonna go check out, and if one is in good enough shape, do a little surgery! Looks like I'll have to unbolt the cowl/firewall from the fenders and the fender aprons, and sawzall away! Sounds like I should bring a spot weld cutter and respirator with me as well!
Again, thank you so much!
Old Sep 19, 2021 | 09:56 AM
5851a's Avatar
5851a
Last major sheet metal replacement I had anything to do with was a late 80's Ranger roof, I know not the same but there was over 200 spot-welds to cut. Kind of why I did cab swap last time.
Old Sep 19, 2021 | 10:00 AM
ArtWebb's Avatar
ArtWebb
Ugh. That's brutal.
Well, before I drive two hours to the yard, I'm definitely gonna get clarity from my shop on exactly what they need. Cutting over 200 spot welds is definitely not in my future!!!
RUSTEZE
May 7, 2021 07:20 AM
Ninja32
Jul 15, 2015 12:47 PM
bkampbel
Paint & Bodywork
Jan 25, 2005 10:51 AM
gatorfan
Paint & Bodywork
Sep 23, 2004 09:04 PM
phaffy12
Mar 10, 2004 10:48 PM
