hood vent replacement
Old Jul 13, 2015 | 09:33 PM
Ninja32's Avatar
Ninja32
So I look through the vents on the hood and can see some rust on the bottom of the channel. Does anyone know if I cut out those vents if there is a replacement that can fit back into the hole? Would make nicer access in the future to clean it out
Thanks
Paul
Old Jul 13, 2015 | 09:35 PM
Ninja32's Avatar
Ninja32
Just trying to figure out best way to resolve that issue I guess...I'm sure one of you guys has fixed that in the past perhaps...
Old Jul 14, 2015 | 12:45 AM
HIO Silver's Avatar
HIO Silver
No one makes replacement panels for the cowl. Either carefully cut out the cowl, do the repair, and weld it back in. Alternatively, find a donor for replacement metal. Another way is to fix it from the inside which basically requires removimg the entire dash for access. The bright side is that the cowl need not be repainted.
A stop gap measure is to visit a sign shop and pick up some magnetic sheeting, cut too size, and install over the cowl slits when parked or stored.
The cowl is a "balloon" assembly. Meaning, it is welded shut... stoopid idea of the Ford engineers unlike the GM engineers who had the better sense and forethought to design the cowl with a removable panel.
Old Jul 14, 2015 | 01:19 AM
Ninja32's Avatar
Ninja32
Ya may have to cut the bottom out of it and weld in a new piece I guess...
Old Jul 14, 2015 | 02:11 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Come on man, what is with the rant on the cowl? Go look at a GM cowl, you will see how cheesy it is. There is no stupid engineering going on there.
Old Jul 14, 2015 | 02:23 AM
78_f800crewcab4x4
Cowl removed in a couple hours, all spot welds, no cutting:
Donor cowl set in place:
The rust will start at the joint at the upper firewall (not galvanized) and bottom of cowl (galvanized). You can just cut out the rusty areas at top of firewall and access the adjacent panel on bottom of cowl to repair without removing the cowl if you want to save time.
Old Jul 14, 2015 | 08:53 AM
HIO Silver's Avatar
HIO Silver
My criticism precisely illustrated. Thanks.
Old Jul 14, 2015 | 11:17 PM
Jrgunn5150's Avatar
Jrgunn5150
Well it looks like I'll be removing my windshield, dash, and cowl then lol.
Thanks for the pics!
Old Jul 15, 2015 | 10:49 AM
akguy09's Avatar
akguy09
Since I will need to paint my truck anyway I just went ahead an cut my cowl vents out and then cut the rusty metal out of the cowl and welded new sheet metal in, then welded the cowl vents back in.
Heres the link to build, it includes pictures of what I did. Keep in mind I have good welding skills, so that might affect your decision.
https://www.ford-trucks.com/forums/1...man-build.html
Old Jul 15, 2015 | 12:47 PM
Jrgunn5150's Avatar
Jrgunn5150
I have mediocre welding skills... But I guess I'll have to see how it looks once I get the dash out, as I have some A pillar rust also.
3twinridges
Nov 6, 2017 08:46 PM
sseebart
Sep 16, 2014 04:52 PM
bulletsneverlie
Paint & Bodywork
Apr 12, 2009 11:19 PM
doug51f1
18
Oct 31, 2006 08:02 AM
hilltopfarms
Mar 17, 2005 04:29 PM
