Big ignition problem, help please
Old Sep 11, 2021 | 08:59 PM
KingDeleted's Avatar
KingDeleted
I have a 1995 e350 with the 7.3. Today, I drove to a car show and parked the van. I went to start it hours later only to find the ignition switch inoperable. It has lost the click click feeling and wouldn’t start the van.
I go over to the parts store for a new ignition cylinder and promptly replace it. The truck starts first try. The problem was fixed, or so I thought.
I drive home and go to shut down the van down, only to find I can’t. I put the key off and remove it and the truck still is clack a lacking like no ones business. Any thoughts or help would be much appreciated. I did eventually get the truck to shut down by pulling a fuse in the power distribution box.
Also I had to disconnect the batteries because the radio would not power off. It’s as if the ignition cylinder lost its function. What can cause this and how do I fix it? Thank you all very much for reading my story and trying to help me out
-Marc
Old Sep 11, 2021 | 09:43 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The lock cylinder is NOT the ignition switch.
The switch is located halfway down the column on top and there is a rod from the lock cylinder that actuates the switch.
Old Sep 11, 2021 | 09:49 PM
KingDeleted
Ok thanks for the info. Is the rod something that can come lose? Is it worth tearing it open, What do you suggest I do?
Old Sep 12, 2021 | 07:00 AM
oldbird1965's Avatar
oldbird1965
Its not worth tearing it open, just get a new one. They are pretty cheap and a common failure.
Foundonroaddrivin
Jul 6, 2018 02:22 PM
cutmoney
Oct 24, 2013 02:58 PM
Jgostrenga49855
31
Mar 6, 2013 04:50 PM
puffins
Oct 1, 2002 07:46 AM
puffins
Sep 30, 2002 10:43 PM
