Mystery Light
Old Sep 11, 2021 | 08:37 AM
motogotor's Avatar
motogotor
Mystery Light
What is this light? Courtesy? E brake warning? Something else?
what bulb does it take and is the cover still available anywhere?
Old Sep 11, 2021 | 10:09 AM
DisneysPatB's Avatar
DisneysPatB
Brake warning light, for system issue.
Old Sep 11, 2021 | 01:57 PM
68Flareside240's Avatar
68Flareside240
These trucks had a brake pressure differential block with a switch inside. In the event of front or rear brake system failure, a barrel in this distribution block would slide, blocking flow to the open system, and triggering the warning light. They appear to be available from most parts vendors. Very common to see them melted. Brakes got replaced, light was never reset and glowed all the time, melting the lens.
Old Sep 13, 2021 | 09:59 AM
wjwolfe82's Avatar
wjwolfe82
I got replacement from LMC a couple years back.
Old Sep 14, 2021 | 07:50 PM
JEFFFAFA's Avatar
JEFFFAFA
Go to www.dennis-carpenter.com. The bezel and lens assembly is their part number D5TZ10A840A. The bulb is industry #1445. You should be able to source it locally.
dh_meyer
2009 - 2014 F150
19
Mar 30, 2021 02:05 PM
Gary Lewis
15
Aug 4, 2013 08:20 PM
Mr.Ford 351W
Garage & Workshop
May 6, 2006 10:40 AM
MustangGT221
Aug 15, 2005 05:47 PM
DPW
Feb 9, 2003 06:37 PM
