First Connection to Upfitter Switch
Old Sep 10, 2021 | 05:20 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Added some lights to the rear bumper for hooking up to the trailer or loading or whatever at night.
Were on a sale on amazon, and then when I went to pay, there was another 50% off promo, so the pair only cost me like $7.
Amazon Amazon
The attachment of the mounting brackets to the lights was a real PITA, someone really had their head up their wazoo when they designed them.
But, I got them on, and they work, we'll see just how bright they are this weekend.
Hooked to the #1 switch, and getting that done was a treat in itself. Ford has improved the access to the switch wires, but they could still be lots better.
Old Sep 10, 2021 | 05:45 PM
AlbertaHooter's Avatar
AlbertaHooter
Is this on a ‘22? I was looking at the owners manual and it appears they’ve got 2 sets of wires behind the battery, one marked with a red dot and one set marked with a white dot. Apparently the one with the white dot is already routed through the firewall and behind the kick panel on the passenger side. My thoughts is that this is easier to connect things like a resistor for high idle. Am I correct?
Old Sep 10, 2021 | 06:00 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I believe you have to connect those pass-through wires to the upfitter switch wires at the fuse box to power them up.
Old Sep 10, 2021 | 06:05 PM
AlbertaHooter
Ah ok. So I’d need to get 2 short pieces of wire to go from the wires at the fuse box to the wires behind the battery, and the resistor would be installed behind the kick plate?
Old Sep 10, 2021 | 07:21 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Don't know anything about the high idle mod.
Old Sep 10, 2021 | 07:36 PM
scraprat's Avatar
scraprat
Top Answer: 5
We need a night shot.
One of these days I need to do that mod, nothing like extra light at night in reverse.
Old Sep 10, 2021 | 08:24 PM
4wd6.7L's Avatar
4wd6.7L
Yes, the resistor gets tied into the customer access bundle which is separate from the pass-through wires but also behind the passenger kick panel. One wire from that ties to a pass-through wire of your choice, then you wire that to the upfitter wire of your choice.
Old Sep 10, 2021 | 09:49 PM
AlbertaHooter
Perfect. That’s the info I was looking for. Thanks!!!👍🏻
Old Sep 11, 2021 | 12:16 AM
RubenZ's Avatar
RubenZ
Ya, interested in night shot.
Old Sep 13, 2021 | 08:31 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Okay, here you go...
Old Sep 13, 2021 | 08:55 PM
scraprat's Avatar
scraprat
Top Answer: 5
Nice, never can have too much light at night.
Other than high beams coming at you.
Old Sep 14, 2021 | 05:09 AM
bent-1's Avatar
bent-1
Does it wash out the backup camera display?
Old Sep 14, 2021 | 10:49 AM
VeloBuckeye's Avatar
VeloBuckeye
5th Gear
Question re: the pass-through wires. I found the one end of the pass-through wires (4 of them) in the passenger kick panel area. Where in the engine bay can I find the other end? I'm trying to hook into the upfitter relay box for my High Idle resistor mod.
Thanks!
2020 F-250 PSD Crew Cab Lariat
Old Sep 14, 2021 | 12:54 PM
KeystoneF350's Avatar
KeystoneF350
Should be effective to discourage night time tailgaters too!
Old Sep 14, 2021 | 02:25 PM
jade97's Avatar
jade97
Thanks!
Start at post #55
https://www.ford-trucks.com/forums/1...them-on-4.html
