Sponsored by: Auxito
Cassette to CDplayer
Old Nov 2, 2003 | 09:11 AM
supernova's Avatar
supernova
I have a factory am-fm casette in my '98 and want to put in a factory cd-player. I have heard the wiring harness has to be changed. Does anyone know if this is so and what is involved with changing it? Also what years would fit (97-03?) as I am looking for a used player.
Thanks in advance
Don
Old Nov 2, 2003 | 11:23 AM
LxMan1's Avatar
LxMan1
If you are installing the in-dash unit, it should plug right up.
Jimmy
Old Nov 2, 2003 | 10:59 PM
AegisSailor's Avatar
AegisSailor
I agree, there is no reason th harness should be different it your installing an OEM unit.
BTW, there are aftermarket double din sized head units available if your just trying to avoid using an adapter kit for mounting. Pionneer makes a nice one that has CD and Casette both.
Old Nov 3, 2003 | 07:51 AM
supernova's Avatar
supernova
Thanks for the in-put. If it's a straight swap that would make things easy.
Don
Old Nov 3, 2003 | 05:59 PM
fx4er's Avatar
fx4er
Don
hey Don, if you do this, would you let me know if it is a straight swap/plug in?
robert
Old Nov 3, 2003 | 06:53 PM
aldridgec's Avatar
aldridgec
You can't get a newer stereo as they changed the harness in 99 I beleve. You have to get either a 97 or 98 radio.
99 and up radios are fairly interchangeable. I have a cd/cass radio in mine, only mod is to cut a plastic piece inside the dash.
Old Nov 3, 2003 | 10:24 PM
TEEJAY's Avatar
TEEJAY
Just like to add an idea that worked well for me. I have a 97 F-250 LD and didn't want to rip apart my dash for a CD player. I bought a CD changer for about 100 bucks at Walmart and installed it in my console out of sight. I was able to keep the stock stereo and stock look and play 10 CD's for about the cost of a single in-dash unit.
