2.5L engine crankshaft differences
Old Sep 2, 2021 | 07:16 PM
KenReb's Avatar
KenReb
I have a question concerning the 2.5L single overhead cam engines (Lima) versus the 2.5L Duratec engine, and I appologize if I am posting in the wrong area.
I have a 2.5L industrial engine that is the same as a late 90's Ford Ranger. I am searching for an SAE flywheel for it, and I have found one that fits a newer version which is the same as the Duratec 2.5L engine. My question is, do they both use the same crankshaft, and/or are they drilled to use the same flywheel?
Thanks in advance for any help.
Ken
Old Sep 5, 2021 | 09:33 AM
pawpaw's Avatar
pawpaw
I see you don't have any replies yet & I don't know squat about the 4banger parts But you may be able to derive the answer by noting if both flywheels have the same part number.
Old Sep 5, 2021 | 12:34 PM
KenReb's Avatar
KenReb
So far I have not been able to find it listed, but it also appears that all of the transmissions listed for the Duratec engines are different than those of the Lima engines.If I could find one that was not installed in a vehicle and did not have the flywheel attached I could verify the fit easily.
Thanks for the help
Ken
Old Sep 5, 2021 | 12:47 PM
pawpaw's Avatar
pawpaw
Have you tried looking the flywheel part numbers up on the online Ford parts website here Parts.Ford.com | The Ford Parts Site | Buy OEM Ford Parts Online‎
Old Sep 5, 2021 | 01:01 PM
KenReb's Avatar
KenReb
Yes, parts are not listed as interchangeable, but they still may be same spacing, that's what I'm trying to find out.
Old Sep 5, 2021 | 02:01 PM
pawpaw's Avatar
pawpaw
Ok, so lets think about this some more. Bet your local salvage yard would know, or have ref material that would. If no replies here, you might ask on the FTE engine forum. 4 Cylinder Engines - Ford Truck Enthusiasts Forums (ford-trucks.com)
dmock
Sep 19, 2019 08:07 PM
Itz2eazy
Apr 6, 2013 10:05 PM
obergene
May 18, 2009 11:24 PM
jensdittmar
22
Oct 10, 2006 07:48 AM
mgundry
26
Mar 16, 2004 12:23 AM
