94 E150 automatic shift delay
Old Aug 31, 2021 | 03:45 PM
Ebinflow's Avatar
Ebinflow
4wd Low
I have a 94 e150 with a 5.0 not sure what transmission. IT won’t shift until it hits 35mph and the motor is high rpms SOMETIMES letting of gas will help it shift for a second but if it’s under 35 mph it jumps right back down. I also notice it does this but not as bad in the last gear.
I have a feeling it’s my gauge cluster shorting, because my air bag light, abs light, and check engine light come in randomly.
but the note about the speed dependancy makes me wonder if it’s something else.
also the OD light comes on but I could feel a difference in driving and no flashing or light but I didn’t leave it on long.
odometer and speed read fine
(update: also if I shift manually it does fine going into 2nd)
Old Aug 31, 2021 | 08:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is to read the codes. Here is a way to do that: Trouble Codes
Old Sep 1, 2021 | 02:08 PM
Ebinflow's Avatar
Ebinflow
4wd Low
i cannot seem to find the obd1 location
Old Sep 1, 2021 | 05:33 PM
Mark Kovalsky
It's been a couple decades since I worked on one of those. If I remember correctly it is under the hood on the passenger's side, towards the back.
Old Sep 1, 2021 | 08:27 PM
NICKSAN's Avatar
NICKSAN
On my 94, 5.8 the obd1 connector is on the drivers side between the battery and wheel well, one large one and small one. May or may not be the same on your 5.0.
The airbag and abs lights coming on randomly "may" also be a failing clockspring wire.
Old Sep 2, 2021 | 10:39 AM
Ebinflow's Avatar
Ebinflow
4wd Low
got the codes
key on engine off
121- Clossed throttle voltage higher or lower than expected.
124- TP voltage was higher than expected - Fuel control
key on engine running
998- hard fault present
22- bp sensor out of range
do y’all think it’s safe to assume it’s my TPS sensor???!! That’d be awesome
or maybe map sensor (bp), although I did just u plug and replay this in while it was off, idk if that will throw a code ?
Another question… if I replace the tps do I have to remove the throttle body?
Old Sep 3, 2021 | 01:29 PM
Ebinflow's Avatar
Ebinflow
4wd Low
FIXED!!!!
I replaced the tps sensor and..:…. She runs like a dream. Thank y’all!
the awesome part is I bought this van super cheap a week ago cause it seemingly had transmission problems. They replaced everything trying to get it to run better to cap rotor wires, new fuel system including injectors! I’m so pumped
Old Sep 3, 2021 | 08:31 PM
NICKSAN's Avatar
NICKSAN
Originally Posted by Ebinflow
FIXED!!!!
Nice to hear you got it going..... and such an easy fix.
Bueller
32
Apr 17, 2019 03:49 AM
nomadw8
Nov 3, 2018 10:14 PM
maginskyk
Sep 3, 2012 11:46 AM
