"Backfire" - Downhill Only / Not Under Load?
Old May 25, 2022 | 10:06 AM
udsuth78's Avatar
udsuth78
Have you seen any noticable change in mpg, or fluid consumption? The PCM uses the IAT, MAT, EOT, MAP, and BARO for fuel strategies plus CPS for injection timing. So if no faults can be found in the electrical side, then we look at mechanical. Pushrods, lifters, and valve springs are what comes to mind with the symptoms you describe.
Old May 25, 2022 | 10:46 AM
freerider15's Avatar
freerider15
Wow. I haven't seen or heard of one of those since I left corporate America.
I'm an engineer, and going through a masters for engineering...so use it a bit
Hard to tell really, since I drive it so little. I "seems" to be about the same, but I haven't done a MPG calc in a while. Fluid consumption as far as? Oil doesn't seem to be anything more than normal (that I can tell), but I change it every year, and usually put maybe a few thousand miles on the truck a year.
Only thing I could think of offhand would somehow be all the oil that was getting into my fuel system (think was smoking like a freight train prior to pulling the injector), would be akin to a bend pushrod, bad valve seal, etc.
I could at some point see about a compression test, then also a leak down test to see if any intake/exhaust valves aren't fully closing.
Old May 25, 2022 | 11:53 AM
brokestroke's Avatar
brokestroke
I have a 95 OBS that did this for years. Coasting down a hill @2100, letting off and then getting back into the throttle it would back fire, pop and throw blue smoke. Would also pop and smoke when free revving @2100-2300rpm. Drove it for years because it didn't change how it drove. One day I changed out the CPS and it never popped or smoked again.
*edit*
The truck would also smoke like crazy when it was cold , fill the whole yard with blue/white smoke. That changed when I swapped the CPS as well.
Old May 25, 2022 | 11:57 AM
freerider15
That's interesting.
Ironically, I did change the CPS out when troubleshooting the bad running condition (what turned out to be a bad injector o-ring) from the one in there (both OE). Went from Gray to Blue I believe.
I'll throw the old CPS in, since I didn't have this problem prior to the CPS changeout...worth a shot!
Old May 25, 2022 | 12:23 PM
FordTruckNoob's Avatar
FordTruckNoob
Flowcharts too then.
hawaii f-550
21
Nov 14, 2013 10:21 AM
Kdr358
Jan 20, 2013 08:06 PM
JWAbercrombie
1997 - 2003 F150
Jan 17, 2013 06:44 PM
DIYMechanic
Sep 24, 2011 06:44 AM
EMD_DRIVER
Jun 18, 2011 06:16 PM
