PCV/Breather
Old Aug 28, 2021 | 09:40 AM
Chevra's Avatar
Chevra
PCV/Breather
Recently had my 302 rebuilt and was working on my breather setup. Without thinking to much I ended up buying this Edelbrock breather. https://www.summitracing.com/parts/e...iABEgL9yfD_BwE
I didn't realize that it wasn't a PCV valve until I got it. It basically just has a small baffle and a foam filter inside but is otherwise a straight through design. I have it installed on the passenger side valve cover and hose hooked into the base of my Street Demon carb. I have a different style breather on the driver side valve cover to.
This obviously messed up my carb tuning a bit since it is sucking a fair amount of air through it at idle, had to richen up the idle mixture screws. But my question is, does this type of setup have any ill effects on the engine, or efficiency? Is it better to swap it out for an actual PCV valve, since they aren't expensive anyways. I'm mostly just curious now.
Old Aug 28, 2021 | 09:45 AM
85e150's Avatar
85e150
Swap it out for the OEM pcv and grommet. What you have there now is a giant oil sucking vacuum leak.
Old Aug 28, 2021 | 01:46 PM
Chevra's Avatar
Chevra
Okay thats all I need to know! Will find a PCV valve for it next week. I don't have OEM valve covers anymore so I will have to figure out what will fit.
Old Aug 28, 2021 | 04:56 PM
Ken Blythen's Avatar
Ken Blythen
x2
The value of correct PCV valves is often overlooked (in the same way that OEM hot/cold air intake systems are).
Old Aug 28, 2021 | 05:33 PM
Chevra's Avatar
Chevra
Originally Posted by Ken Blythen
x2
How would one figure out the correct PCV valve needed? I am not dealing with a factory spec 302 anymore haha.
Old Aug 28, 2021 | 05:37 PM
85e150's Avatar
85e150
How far off of stock are you?
Just start with the OEM one. What you have now is a serious fubar.
Old Aug 28, 2021 | 06:01 PM
Chevra's Avatar
Chevra
Its not a crazy engine build so I'm sure the OEM will be just fine. Will start there. Thanks for the info
Old Aug 28, 2021 | 10:04 PM
Franklin2's Avatar
Franklin2
Put the original PCV valve in place. And make sure your aftermarket valve covers have shields or baffles under the grommet area inside the cover. If they don't, the PCV valve will suck a lot of oil also, making the engine use a lot of oil.
Old Aug 29, 2021 | 07:14 AM
FuzzFace2's Avatar
FuzzFace2
Got to love after market valve covers
On the PCV just get the one for your year truck / motor.
As said there needs to be a baffle under the valve or it will suck up oil and that may be an issue with your covers?
Now the PVC is in 1 cover and you need fresh air coming in from the other cover.
That breather you have now could be used on the other side and a hose run up to the air filter where there is a breather filter in it that filters air before it is pulled into the motor.
Dave ----
Old Aug 29, 2021 | 08:46 AM
Chevra's Avatar
Chevra
My valve covers are baffled so I am good there.
FuzzFace that is not a bad idea for the breather. My Demon air cleaner has spots for connecting that so I might do that later on. My current fresh air breather just has it own filter.
Old Aug 29, 2021 | 04:09 PM
FuzzFace2's Avatar
FuzzFace2
OK I just wanted to post up how it should be in case anyone finds this on a search and now knows how it should be.
Dave ----
Colo79Ford
Aug 19, 2006 05:33 PM
jaye
Mar 15, 2006 02:41 PM
Brian460
May 13, 2004 10:07 PM
Saurian
18
Apr 22, 2004 05:00 PM
71ranchero500
Jul 25, 2003 12:44 PM
