2022 Super Duty issue
Old Aug 27, 2021 | 10:26 PM
Klinc's Avatar
Klinc
Originally Posted by Lestatsghost
At least the truck tells you to check the back seat when you get out, because if you lock it those left are not getting out those 2 doors.
That's why I don't lock it until everyone is out. It's worked well for me for 20+ years.
And anyone I know knows how a vehicle door lock works.
Old Aug 27, 2021 | 10:40 PM
4wd6.7L's Avatar
4wd6.7L
Well there is a way to get out of a locked trunk now so...
All I'm saying is review page 84 I have included a screen shot of it. It doesn't work as stated. There is a reason it's in the manual.
Interesting seeing that. The 22's have a few different features compared to my 19. The 2019 manual has no wording describing any two step process of opening the rear doors. They wont unlock unless the unlock button is pressed or the drivers door is opened after shutting off. Must not be a safety concern since it was that way for several years. I do understand that if it says it should work a certain way then it should.
Have you tried with and without the Autounlock on? With it off maybe that double pull of the inside rear handle will work.
Old Aug 28, 2021 | 05:31 AM
cpobst's Avatar
cpobst
Unless they have a pulse and they pull the locks up.
Old Aug 28, 2021 | 08:09 AM
gijoe411's Avatar
gijoe411
Seems like more of a misprint in the manual than a manufacturing defect.
Old Aug 28, 2021 | 08:59 AM
Brantel's Avatar
Brantel
Checked mine this morning. Handle will not unlock it.
Old Aug 28, 2021 | 12:15 PM
FoxBraap's Avatar
FoxBraap
This is how my 2019 is also. The passengers in the back cannot open their doors with the handle until I open my driver door unless they pull the plunger up first
Old Aug 28, 2021 | 04:08 PM
Tsubakihara's Avatar
Tsubakihara
My 2022 350 KR has a major safety issue. However it isn't just mine. None of the 2022's my dealer has received can perform this major safety issue. The issue is the rear doors will not unlock if you pull on the interior handle. No matter how many times you pull will it unlock an open the door. If you actually read your owners manual, yeah who does that, you will find on page 84 the very first thing written is how to unlock and open the rear doors. Pull once unlock pull again to open. My dealer has contacted Ford directly as mine, and 3 others they have, do not do this. Their service department doesn't even know how to fix this. They did also receive 2021's on the same truck load and all of those do this action correctly. The dealer and their service department believes this will become a recall as if the cab is smashed to the front doors there is no way for the rear passengers to exit the vehicle unless they know the old school way to pull on the physical lock stalk sticking out of the door. Be advised as to when you use auto lock.
Try turning the child lock in the door.
Old Aug 28, 2021 | 07:38 PM
JHForman812's Avatar
JHForman812
just checked my 19 it’s same as yours. You gotta pull the lock up to get out. I think I’d prefer it this way personally so my kids don’t inadvertently open the doors cruising down the road.
Old Aug 29, 2021 | 09:35 PM
Applecore5's Avatar
Applecore5
Originally Posted by cpobst
I don't see this as a major safety issue. But then again my first car had manual locks, manual windows and an 8-track. If you can't pull the lock up on the door then you probably won't stand much of a chance in life anyway.
I do see it as a safety issue. It doesn't work as the manual explains. That's a problem. Think child, let's say 10 years old, cab is crushed to front seats and parents totally unavailable. If said child (or adult in the back seats really) can't reach the plunger...how are they supposed to get out?????? If the door can open, it should open, even locked unless the child locks are on, which is a deliberate action. In the 2022 it's
permanent child lock in the back seats. "THESE DAYS" (vehicles made recently) most all cars work like that...even locked you can get out in the event of an emergency unless you deliberately use the child lock on the rear seats. Also, most cars built now don't even have a plunger to pull up to unlock the rear doors. It's a simple 2 pull action to get out...again for an emergency.
Old Aug 30, 2021 | 12:15 AM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by Applecore5
In the 2022 it's
I agree to the extent that the doors should function as described in the manual. Keep in mind that up until 2021MY Super Duty (vehicle made recently) the rear doors did not function in the manner described in your 2022 manual, and there was no such description in the owners manual. They required the unlock button to be pressed, or the drivers door to be opened after shut off, or the lock plunger to be lifted. Were they death traps for children? I haven't found any data to make me think that.
I posted the question previously in this thread but I don't think it got an answer....on the 2022, if Autounlock is disabled do the rear doors open with the double handle pull?
Old Aug 30, 2021 | 12:20 AM
Applecore5's Avatar
Applecore5
yes. They will. But nothing is locked at that point.
Old Aug 30, 2021 | 12:24 AM
4wd6.7L's Avatar
4wd6.7L
Huh? Then lock the doors and try it haha. When you start to drive the doors Autolock, not sure if that can be turned off, Autounlock can be turned off though according to the manual.
Old Aug 30, 2021 | 12:32 AM
  #28
Applecore5's Avatar
Applecore5
I read that wrong sorry. if auto lock is enabled nobody in the rear seat and get out no matter the situation. If it's disabled no doors lock unless there are manually locked. In which case the rear seat is child safety locked.
Old Aug 30, 2021 | 12:39 AM
  #29
4wd6.7L's Avatar
4wd6.7L
In the manual I only see reference to enabling and disabling Autounlock, not Autolock. So I assumed Autolock is always on. That's why I was curious if Autounlock made any difference to the double pull function. It sounds like you are saying with Autounlock enabled, or disabled, the double pull does not open the rear doors. Just like it was on the pre-2022 models.
Old Aug 30, 2021 | 09:00 AM
  #30
GAZZILLA's Avatar
GAZZILLA
The rear doors on a super cab can’t be opened without first opening the front doors.
