Sponsored by: Real Truck
High beam failure
Old Aug 27, 2021 | 11:30 AM
264WSM's Avatar
264WSM
High beam failure
Seems that I have gone thru 3 multi-function switches in 3 years!! All 3 have had a high beam failure issue. When I turn the high beams on - all headlights go out! I find it hard to believe that the MFS failed that often so it has to be something else. A buddy said it would be the relay, but I see no relay part listed in the high beam circuit. Is it called something else? Where would this relay be? Under the hood or dash?
Old Aug 27, 2021 | 11:52 AM
projectSHO89's Avatar
projectSHO89
It might help if you identified what you're working on...
Old Aug 27, 2021 | 02:42 PM
264WSM's Avatar
264WSM
Ooops! 2000 F-350 dually PSD
Old Aug 27, 2021 | 03:55 PM
projectSHO89
Does the flash-to-pass feature work?
Old Aug 27, 2021 | 05:58 PM
264WSM's Avatar
264WSM
No, all lights go out then too
Old Aug 29, 2021 | 06:21 PM
lshort's Avatar
lshort
Where are you getting the switches. I have had repeated problems with electrical items from one of the big chain parts stores,
Old Aug 29, 2021 | 09:51 PM
josht's Avatar
josht
So are you saying that you install a new MFS, it works for a while, then it has the same failure?
Is the switch burning out, or maybe a problem at the connector so it works a while after you mess with it then eventually goes bad again?
That does seem like an odd coincidence that they'd fail the same way all three times unless there is a design flaw that causes it. It's not on a Ford, but my little Kia has a problem with it's MFS. Not as serious as your issue, but the fog light circuit failed in the MFS and it's failed in the same way on a lot of this model, but apparently not enough to cause a recall. It was a design flaw where the lead going to the switch was made too short and stresses (eventually breaking) the connection at the switch. Got the parts, but haven't gotten around to fixing it yet.
Old Aug 30, 2021 | 06:08 AM
projectSHO89
Then it's likely the MFS failed again (for whatever reason). There is no relay in the circuit as proposed by your buddy.
If all of the lighting is OEM, then it would pretty much be necessary to dissect the failed switch for more clues as to the repeated failures. If you have non-OEM headlights installed, I'd speculate that they're pulling too much power and the switch is being overloaded.
Old Aug 30, 2021 | 11:00 AM
josht's Avatar
josht
That's what I was wondering about too. If that's the case adding relays would be a simple fix to the problem.
Old Aug 30, 2021 | 07:14 PM
Bigger Hammer's Avatar
Bigger Hammer
Doesn't explain the problem you're having, but I think in general Ford truck don't have solenoids in their headlight harnesses, so everything has to go through the switch. Several companies make kits to add solenoids, primarily to brighten lights up, you can buy theirs or copy them yourself.
These aren't cheap, but better quality than most others and work well:
CE Auto Electric Supply Headlight Relay Kits
Old Sep 7, 2021 | 09:13 PM
264WSM's Avatar
264WSM
The MFS failed once with OEM Halogen lights. I eventually put LED in the headlight positions, and the second MFS failed. Third MFS failed after being there for 2 months. The kicker is; I don't drive this truck much and very little at night especially in the summer. In a year of driving I might only use my headlights/high beams 50 times!
351Cleveland C4
19
Aug 25, 2020 07:41 PM
ruphianh
Dec 21, 2016 08:27 AM
Ben Albert
Nov 1, 2010 10:36 PM
PwerStroke99
34
Nov 3, 2009 11:12 AM
ivanribic
Electrical Systems/Wiring
Mar 15, 2005 12:48 AM
