AC woes
Old Aug 26, 2021 | 11:59 AM
bradpowell3557's Avatar
bradpowell3557
AC woes
Blend door motor not working properly, does entire dash have to be removed?
Old Aug 27, 2021 | 12:29 AM
bobcat67's Avatar
bobcat67
Really depends on the truck, but simple answer, yes
Old Aug 27, 2021 | 05:57 AM
bradpowell3557
Thank you Bob Cat
Old Aug 27, 2021 | 09:32 AM
Fefanatic's Avatar
Fefanatic
The very early 2011's have issues with the blend door and Ford had a bulletin out to replace the whole plenum assembly. Yes the dash has to come out. Been there and done that.
Old Aug 27, 2021 | 10:34 AM
bradpowell3557
thank you Fefanatic
Old Aug 27, 2021 | 10:36 AM
bradpowell3557
If you remove the center console can you get to from bottom?
Old Aug 27, 2021 | 12:17 PM
Braggs's Avatar
Braggs
Wow, Ford had blend door problems going all the way back to 1985 or earlier. You'd think they would learn their problem and use a hinge rather than a crimped piece of plastic.
Old Aug 27, 2021 | 01:46 PM
Fefanatic's Avatar
Fefanatic
No console removal will get to it. As for the blend door problem it's not the door but the design of the plenum, that's why they recommended replacement. We installed a used one from a 2014 to correct our issue.
Old Aug 29, 2021 | 11:11 PM
Chad149's Avatar
Chad149
If you have the climate box/plenum out, change the evaporator while your there.
loudfords
Apr 29, 2017 08:02 PM
50f6
Jul 1, 2016 05:09 PM
fnx4wheeler
Sep 19, 2013 01:10 PM
kidder
1983 - 2012 Ranger & B-Series
Jun 28, 2010 10:24 AM
