Sponsored by: Real Truck
2016 Front End Vibration, your thoughts please.
Old Aug 25, 2021 | 07:38 PM
Firefighter 1406's Avatar
Firefighter 1406
Okay. 2016 F-250 CC 4x4 w/ 6.2L. I have owned this truck for about 3 months. Has driven great and was very impressed with the ride. About 3 weeks ago we were camping and pulling the camper and on the interstate I noticed a slight vibration in the front end and felt it all the way into the wheel. I did have two new tires installed on the rear before the trip and put the older rears into the front. So brand new BFG All Terrains on the rear and the same tires on the front with around 10K on them. When I got back from the trip I took the truck back to the tire shop and had them balance the tires that were moved from the rear. Picked up the truck with no change. It seems to do it more in the 25-60 mph range. Anyways I have a few steering parts that show a little wear when squeezed together with channel locks but they didn’t seem enough to worry about it yet.( Attached Videos).
Possible causes:
1. Bent rim and need to rotate tires back to the rear to confirm.
2. Slightly worn out steering parts that are causing issues.
3. I am going crazy (hope not yet)
4. Your thoughts or suggestions.
https://flic.kr/p/2mjhnJ8
https://flic.kr/p/2mjhofP
Old Aug 27, 2021 | 12:59 PM
SteveH-CO's Avatar
SteveH-CO
Be sure your hubs are both unlocked (I mean internally - not just that you are not in 4WD). One or both hubs failing to unlock can cause vibrations at speed.
Old Aug 27, 2021 | 06:18 PM
Firefighter 1406
I appreciate the idea. I have verified that both are unlocked however I will check again. Thank you again for the suggestion.
Kevin Burroughs
Jun 12, 2021 01:43 PM
GracieAllen
15
May 23, 2020 04:04 PM
Loopy
Dec 17, 2010 09:46 PM
Sicko
16
Jan 6, 2005 07:11 PM
zamboni guy
1983 - 2012 Ranger & B-Series
Nov 9, 2004 06:21 AM
