360/390 engine identificdation
Old Nov 1, 2003 | 03:57 PM
76  F250 4X4's Avatar
76 F250 4X4
Other than the flywheel end of the crankshaft can you identify whether an FE engine is a 360 or a 390 from casting #s or other #s that are visable from the outside of the engine? Can the year of the engine be determined from the #s?
Old Nov 1, 2003 | 07:11 PM
Dealford's Avatar
Dealford
Both the 360 and 390 are 4.050 bore blocks. The 360 has 3.50 stroke, while the 390 has a 3.78 stroke. The answer to your question is genarally no. The only way to tell one from the other is measure the stroke. By taking out one or all the spark plugs and useing a dowel in the spark plug hole, turn the engine over by hand and measure the distance the piston travels.
Old Nov 1, 2003 | 11:18 PM
76 F250 4X4
So, there are no #s, cast or stamped,
or other external physical features to determine if an engine is a 360 or 390 or what year truck it came in? That means I can buy any 390 frome a boneyard, install it in my truck and no one could tell it from the original 360 except by measuring the stroke through a sparkplug hole or by looking at the flywheel end of the crank. Is that correct? Are the cams and the carbs the same?
Old Nov 2, 2003 | 01:31 AM
Ratsmoker's Avatar
Ratsmoker
The ONLY difference between the two engines is the crank, rods and pistons. They used the exact same blocks for each engine. Carb, cam, heads, etc.. are all identical.
Old Nov 2, 2003 | 10:22 AM
76 F250 4X4
Serial #
Do these engines have serial #s or date codes stamped into them?
Old Nov 2, 2003 | 05:30 PM
Dealford's Avatar
Dealford
The date code is small & it's located between the oil filter adapter pad and the pan rail. The block casting code will not help you identify exactly which it is. Example - C6ME-A could be a 410 or a 330FT etc.,etc.
teason72
15
May 1, 2012 08:05 AM
pittmick
Dec 30, 2009 07:37 PM
jarmeister
17
Feb 25, 2006 07:31 PM
76 F250 4X4
Dec 15, 2003 06:32 AM
mforren
May 8, 2000 09:49 PM
