transmission leaks
Old Nov 1, 2003 | 03:13 PM
pt2's Avatar
pt2
transmission leaks
I have a '90 E250 4.9L and when I park it in certain positions, generaly front end slightly down it leaks fluid. When it is parked front end slightly higher little or no leak. In 24HRS it leaked a puddle about the size of a dinner plate. Any one know how to fix or what as wrong? Thanks
Old Nov 1, 2003 | 03:33 PM
95BlackF150's Avatar
95BlackF150
front seal. replace it
Old Nov 2, 2003 | 04:11 PM
pt2's Avatar
pt2
I replaced it the other year. Any chance of it leaking out around the dip stick tube where it attaches to the transmission?
Old Nov 2, 2003 | 04:25 PM
95BlackF150
only if the o ring isn't on there right or is broken but its possible its also possible that the seal is bad to i just put on in the rear of the transfer case bout 3 weeks ago and its leaking again
