Bilstein 5100 shocks
Old Aug 21, 2021 | 10:33 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by 4B11TX
Why 5100 over 4600? I never had 5100's but my 4600 are great.
My reasoning is subjective, first reason would be the finish, I prefer the silver zinc coating of the 5100's over the yellow/blue of the 4600's. Also, the 5100's provide a small amount of additional travel over stock that I don't think the 4600's do. Last reason would be the possibility of the 5100's having a slightly more aggressive valving since they are marketed more towards off-roading, trucks with lifts and larger tires.
Old Aug 21, 2021 | 11:02 PM
Desert Moto's Avatar
Desert Moto
Originally Posted by RubenZ
Which is this BUNDLE. If you look at Part numbers its what you listed: BILSTEIN 5100's For Super Duties
That would work, it's just a one click package for all 4.
I've had both. What I experienced was the 5100's were a little firmer in the initial compression while still retaining some small bump compliance and exhibited more controlled rebound.
Old Aug 22, 2021 | 03:15 PM
Buckeye71's Avatar
Buckeye71
You think the 4600 ride softer than fox 2.0?
Old Aug 22, 2021 | 05:12 PM
Desert Moto
Likely, never compared them side by side. Fox, Kings, Icon and Radflo have an "Entry" level line like the 2.0's. But these companies are next level, so the 2.0's would be at the bottom of their product line, rebuild-able and serviceable, which means they will require nitrogen, fluid changes, seal replacements and the ability to fine tune to your needs but at an expense. If you are looking to just upgrade to "over the counter" type shocks at reasonable prices then the next level shocks may not be for you. MOST over the counter shocks will be an improvement compared to the factory ones we get on the SD's.
Old Aug 22, 2021 | 11:10 PM
Joe T's Avatar
Joe T
I run 4600 on my F150 and fox 2.0 on my recent f250.
They are a bit different. The 4600 really keeps it under control with a load and unloaded are a little bit stiff. The 2.0 let the suspension work a little more and i would say that probably gave a better ride if it was what your concern was. The 2.0 wasn’t a gimmick they are pretty good quality for an entry level performance type of shock. The 2.0 works fine for work as well but if I had a dedicated work truck I would use the 4600.
The 4600 is a good HD shock, I don’t know if anyone makes a better HD shock.
The 5100 isnt as good as the fox 2.0 but works fine. I have used it as a basic entry level shock for lifted applications on a few trucks. I think thats what they were designed for.
I run some Rancho on an older F250 and they ride real smooth. Havent had much time with it to review them but they are pretty cheap so will need to see how they hold up.
Old Aug 23, 2021 | 12:15 PM
Chris 86's Avatar
Chris 86
Originally Posted by Paulphilly
Is it a huge difference over the FX4 stock shocks? I don’t mind to drop the coin for the 5100’s, as long as it’s worth it. Will the 5100’s work on my rig since it’s not lifted 2”-2.5”?
No. I installed the 5100 on my stock fx4 with snowplow package recently There was a very slight difference, but not huge. My stock shocks has 20k on them, and are all still in good shape with only one that had no dampening in the top 3 inches of travel, but that is not a range the suspension would travel in. Truck is a little more controlled over right patches, but not "night and day". People talk about the stock shocks as if the truck can barely drive unless your replace them.
The 5100's were an upgrade. But if you don't have extra money to burn, I would wait.
Old Aug 23, 2021 | 01:59 PM
RubenZ's Avatar
RubenZ
Ya I honestly can say that no matter what upgraded shocks I've ever installed I couldn't say I could tell a huge difference lol.
Old Aug 23, 2021 | 09:31 PM
TCNashville's Avatar
TCNashville
I replaced my factory shocks at 14K with Rancho 5000X. Was the ride better? Not really sure but since I just put brand new shocks on, my mind said they should ride better so yeah, I guess they do, lol.
Old Aug 23, 2021 | 10:05 PM
ibeb's Avatar
ibeb
Just ordered a set from here. Created my account, waited about 15-20 minutes and had an email for another $10 off. $326 and change shipped. Ordered around lunch and had the UPS ship tags before I left work.
https://www.shocksurplus.com/product...d-w-2-2-5-lift
Old Aug 23, 2021 | 10:26 PM
GAZZILLA's Avatar
GAZZILLA
What shocks does the F-250/350 FX4 come with? Who makes them, what are their specs and features? I’ve read good reviews about the Tremor shocks but the Tremor is lifted from the factory, so I don’t think they will work on a non Tremor truck.
To except a improvement you have to know what you have and what the difference is on what you’re replacing it with. You could be buying a equal or worse shock if you don’t know.
Old Aug 23, 2021 | 10:51 PM
BirchyBoy's Avatar
BirchyBoy
I ordered on Sunday and the tracking says they’ll be here on Wednesday. I’ll get them installed this weekend along with my Five Star tune.
Old Aug 24, 2021 | 09:18 AM
ibeb's Avatar
ibeb
Tracking says I should have mine tomorrow too. If it is as simple as swapping other shocks, may install after work. I plan on measuring the OEM shocks to get a full compressed length and fully extended length for comparison against the 5100's. I have an F350 Tremor, so the Tremor shocks, Bilstein's site says they won't fit, but everyone else that has ordered and installed them says they fit just fine.
Old Aug 24, 2021 | 10:20 AM
  #28
El Chupacabra's Avatar
El Chupacabra
I got my set from there too. They shipped fast. I only found a $5 off code though... Still the cheapest place I could find to buy all four.
Old Aug 24, 2021 | 10:22 AM
  #29
acadianbob's Avatar
acadianbob
How can a shock, that is firmer on initial compression, improve the ride? My 2021 F350 rides great; real nice on small impacts. I would think a firmer shock would degrade the ride. Educate me.
Old Aug 24, 2021 | 10:29 AM
  #30
RubenZ's Avatar
RubenZ
Because the shocks purpose is to stabilize the vehicle after hitting or going over bumps. A less firm shock will bounce lot. A firmer shock will prevent the 2nd, 3rd or 4h bounce after hitting bumps.
