making a 3.0 run better?
Old Nov 1, 2003 | 01:28 PM
1991rangerford's Avatar
1991rangerford
My dad bought a 1995 3.0 Auto extend cab a few months ago.
last night he drove my 4.0 auto and he couldn't believe how gutless his 3.0 seemed.
Are they any bolt on mods that would give him a little more power?
Intake suggestions?
Cat-back exhaust?
anything that will help will be apperciated.
Old Nov 1, 2003 | 06:29 PM
Dealford's Avatar
Dealford
The guys here talk about the mods once and a while. There are parts available for the 3.0. You'll notice that in some posts there are words highlighted in blue. Click on them and that will taske you to the store.
Old Nov 1, 2003 | 08:50 PM
Ken00's Avatar
Ken00
An intake, cat-back and a chip will help, you should be able to get them at our parts store.
Old Nov 1, 2003 | 09:15 PM
1991rangerford
anyone have some better info than suggesting a store ran by the forum?
Some actual numbers and suggetions?
Old Nov 1, 2003 | 09:31 PM
Ken00's Avatar
Ken00
I have a Gibson cat-back that I like, have heard good things about diablo chips and K&N makes quality intakes. Most brands are going to give you similar results, its more of a personel prefence thing.
Old Nov 2, 2003 | 03:40 PM
1991rangerford
Thanks Ken!
i'll tell him to look into a K&N and the chip...
Ther eis a guy here local that will do a flow master duel exhaust on mini pick ups for 150 bucks, i think i am goign to get it done to my ranger as well
Old Nov 3, 2003 | 01:21 PM
Ken00's Avatar
Ken00
Make sure he uses mandrel bent tubing, it makes a BIG difference.
Old Nov 5, 2003 | 12:32 PM
davelaboss's Avatar
davelaboss
Ken,
Why does MBT make a big difference? And what other kind of tubing would it come in?
Thanks,
BOSSMAN
Old Nov 5, 2003 | 02:56 PM
junction99's Avatar
junction99
Mandrel bent tubing keeps the full circular opening through the turns in the pipes. What is the benefit to that? More volume to allow exhaust gasses to exit without restriction.
The other type of tubing is pressure bent that flattens the pipes at turns which produces a restriction to the exhaust gasses.
In a 3" pressure bent pipe you only have 2.5 square inches of volume at the turns where as a mandrel bent pipe has 3.14 square inches of volume at the turns.
Mandrel bent pipes also reduce back pressure by up to 35% which can be good in lots of aplications.
Hope this helps.
Old Nov 6, 2003 | 11:40 AM
Va914's Avatar
Va914
Square inches of volume????
Kerry
Old Nov 6, 2003 | 09:32 PM
cgaffman's Avatar
cgaffman
I have a 2000 3.0 and here's what I've done to increase power:
Jet Chip
JBA Headers
Granatelli MAF Air Flow Sensor
Gibson Exahust
Next: Cold air intake
Big difference in the power. No loss in MPG.
Old Nov 6, 2003 | 09:39 PM
Va914's Avatar
Va914
Where did you get the parts from?
Can you e-mail me with a ball park price for each?
I think I need to start my collection of parts
Cheers
Kerrys914@comcast.net
Old Nov 10, 2003 | 07:28 AM
junction99's Avatar
junction99
Va914,
Why did you write "Square inches of volume????" Do you not understand what this means? If you don't, just ask and it can be explained.
Old Nov 11, 2003 | 07:21 AM
JetBlackEdge's Avatar
JetBlackEdge
Since he has an AUtomatic, it will be that way...... Have him swap his gears to 4.10's. It'll probably be a 7.5 rear end, so the 4.10's will be harder to find.
