mom needs help
Old Nov 1, 2003 | 01:05 PM
kidstruck's Avatar
kidstruck
Question mom needs help
how to install Fuel Filter on a 1994 4cyl. Ford Ranger single mom needs help with this.
Old Nov 1, 2003 | 01:13 PM
billsco's Avatar
billsco
Hi kidstruck,
You may have better luck in another forum. This is garage talk. Try leaving this one and scroll down to the specific truck and/or year.
Best of luck
Old Nov 1, 2003 | 04:17 PM
Mike W's Avatar
Mike W
I have not done this yet but you need a special tool to disconnect the lines. Welcome to FTE.
Old Nov 1, 2003 | 04:21 PM
black98f150's Avatar
black98f150
i know on my f150 you just need the tool that you can get at any parts store for like $10,take off the gas cap to relieve pressure and once you see the tool you will know how to do it,kinda hard to explain in words!!!!!!!!!!good luck from single dad to single mom.......lol
Old Nov 1, 2003 | 04:40 PM
Ranger95's Avatar
Ranger95
Tool is already attached to the fuel line at the filter side, is the one attached with a "string", you just slide it in and will detach the fuel filter.
Old Nov 1, 2003 | 05:34 PM
Richard4447's Avatar
Richard4447
I thought that was a tool on a string was a safety clip to keep the filter from separating from the foward fuel line.
The rear fuel line has a safety clip with a type of white plastic safety pin that goes through the connector housing and around the fuel line connection.
The tool you need looks like the top colorful 'donut' set found at almost any auto parts store.
http://www.autospecialtytools.com/cg...doc=fuel1.dht&
Old Nov 1, 2003 | 08:45 PM
Ken00's Avatar
Ken00
Also pull the connector off the inertia switch and start it to relieve the fuel pressure but you will still get a lot of gas coming out.
Old Nov 1, 2003 | 09:33 PM
Richard4447
kidstruck:
The inertia switch can be found using this page:
http://www.cybrrpartspro.com/Chilton...9131R05_9.html
Old Nov 1, 2003 | 10:20 PM
Peter94's Avatar
Peter94
Yes, even then, have a bucket or somthing ready, cause gas WILL come out of the line after you have depressurized it. I found this out the hard way by laying under the truck!, lucky i had saftey equiptment on, like a facemask!
Old Nov 1, 2003 | 10:46 PM
Ranger95's Avatar
Ranger95
The donuts like tools are for the A/C, I bought them to use it to replace the fuel filter and didn't worked, size will not match, that's how I discovered the actual clip is the tool, I pressed it agaist the fuel line and it unlatched the fuel filter.
