2003 Excursion 6.0
Old Aug 19, 2021 | 07:44 PM
1css's Avatar
1css
2003 Excursion 6.0
The running board lights and interior lights on her Ex won't go off on their own. The dash shows a door is open but everything looks and feels closed. Any ideas about shutting them off? I am considering just yanking the fuse until the weekend. She needs it in the morning so the batteries can't die tonight.
Old Aug 19, 2021 | 11:40 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
You can try spraying WD 40 into the locking mechanism and opening and closing them a few times. Remember that there are two mechanisms on the rear hatch glass about 1/2 way up If that doesn’t work then you could start checking and changing the actuators. Good luck!!!
Old Aug 20, 2021 | 06:07 AM
Tom Compton's Avatar
Tom Compton
I did this on my ‘97 Expedition 8-10 years ago. The third door I treated was the culprit.
Old Aug 20, 2021 | 06:32 AM
1css's Avatar
1css
Thanks. I will start that tonight.
Old Aug 20, 2021 | 02:21 PM
Tunafish389's Avatar
Tunafish389
The wd40 trick works well but if that doesnt work you can try testing the pin out as seen here https://www.justanswer.com/ford/1k3u...-electric.html.. Did this just start and didnt do it before?
Old Aug 20, 2021 | 08:08 PM
1css's Avatar
1css
We bought it about two months ago so I really don't know if it happened before. It did it twice with us for a very short time but never lasted very long.
Old Aug 20, 2021 | 08:30 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Mine does this if it is low on fuel and the A/C is on at the same time, but only once in a while.
Be driving down the road, and the low fuel light comes on, suddenly it says a Door is open, and the interior and step lights all come on. Get Gas and it goes away, or turn off the A/C and it goes away, but since arizona cant leave the A/C off, so the solution for me was get gas if the light comes on, or don't let it run low enough the light comes on.
Weird as heck, but i assume there is a crossed or common circuit between the A/C, Low fuel light, and something else. If it happens, getting gas makes it go away, and so does turning off the A/C. But it only occurs rarely, not every-time the low fuel light comes on with the A/C on.
Old Aug 20, 2021 | 08:37 PM
1css's Avatar
1css
That sounds spooky. Look for ghosts.
Old Aug 20, 2021 | 08:40 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
I know you didnt't mean anything, but please don't joke, i lost my wife 1/3/20, Cardiac, not covid.
Old Aug 21, 2021 | 10:02 AM
1css's Avatar
1css
My apologies. I really did not mean anything by the comment. I am sorry for the loss.
OFE James M
Mar 20, 2024 08:51 PM
Alta
May 30, 2015 06:16 PM
doc4bax
Aug 22, 2011 03:33 PM
stansarno
May 11, 2009 06:19 AM
herman2006
Jan 8, 2006 09:31 PM
