P0700(Milrequest)
Old Aug 19, 2021 | 12:34 PM
Dantaylor's Avatar
Dantaylor
Trailering
P0700(Milrequest)
My 2007 f350 harley davidson edition isn't getting enough preasure for it to engage in any gears it's been this way for over a month changed fluid and both filters there was a lot of fine metal stuck to the magnet no big pieces. Started the truck and it was trying to move but wouldnt move so I pulled the inline filter witch was plugged allready cleaned it and refilled fluid the truck started to move at about 3000 rpm any help or thoughts would b greatly appricated
Old Aug 19, 2021 | 12:44 PM
LindenBruce's Avatar
LindenBruce
When you changed the filter in the pan, did you remove the old filter seal that was prolly stuck inside of the case? Sounds like she's sucking air. B.
Old Aug 19, 2021 | 12:46 PM
Brotherbillstruck's Avatar
Brotherbillstruck
Sorry. See the code in the title. Hopefully Mark K. will be along shortly. I think there would be other codes accompanying the PO 700.
Old Aug 19, 2021 | 12:49 PM
Dantaylor's Avatar
Dantaylor
Trailering
No would that b where the pan filter attaches to the tranny?
Old Aug 19, 2021 | 12:51 PM
Dantaylor's Avatar
Dantaylor
Trailering
I'm also getting a blinking tow haul light and sometimes no throddel when I push the pedal
Old Aug 19, 2021 | 12:54 PM
LindenBruce
Yes, where the filter tub goes into the transmission. The old seal almost always sticks inside of the case. If you don't remove it, you are trying to stack seals. That can cause issues. B.
Old Aug 19, 2021 | 12:56 PM
Dantaylor's Avatar
Dantaylor
Trailering
Ty that will b my next task
Old Aug 19, 2021 | 02:29 PM
xcrsp440's Avatar
xcrsp440
You should check for any DTCs that exist. Can help you greatly in pinpointing the trouble spots.
never mind. I didn’t see the DTC in the header.
Old Aug 19, 2021 | 05:55 PM
LindenBruce
Yeah, the DTC he listed, from my quick research, is a general code that basically says something is wrong with me. He SHOULD have a second, at minimum, DTC that will be pointing to a more specific issue within the transmission. But one is not listed. So your question is valid xcrsp440. B.
Old Aug 20, 2021 | 09:45 AM
Dantaylor's Avatar
Dantaylor
Trailering
I wish there was other codes that went with it I've been pulling the inline filter and cleaning it out and I've been able to get the truck to move but not very for her thank you for your help though
Old Aug 20, 2021 | 10:07 AM
Brotherbillstruck
I don't know what to do about having two threads going so I will answer here. You did not say what you are pulling codes with. Can you post that? Not all methods are equal. Your code is a general trouble code that just says something is wrong from the little reading I did. Not greatly helpful.
Old Aug 20, 2021 | 10:17 AM
Dantaylor's Avatar
Dantaylor
Trailering
I'm pulling the codes with the in Nova 3600 I also have a Diagnostics on my tuner SCT tuner and that's what I was thinking to that I should get more codes than just that but I'm not
Old Aug 20, 2021 | 11:00 AM
Brotherbillstruck
I have read here that the SCT is not the best at reading codes. An inexpensive tool to add to your arsenal would be Forscan/ Forscan Lite paired with and OBD dongle. Forscan can be downloaded to a laptop for the full version and Forscan Lite(which is almost as good) can be used with a smartphone. Both are less than $10? Whichever smartphone you have( if you do have one) will determine which OBD dongle to buy. With my I Phone I needed to get a wifi enabled dongle. I believe Androids use Bluetooth-I may have those reversed though. You will have a capable code puller for cheap if you go this route.
Old Aug 20, 2021 | 11:09 AM
Dantaylor's Avatar
Dantaylor
Trailering
I will try that when I get off of work and let you know what happened but I just need to do something with it I'm so tired of not having a truck
Old Aug 20, 2021 | 01:55 PM
Dantaylor's Avatar
Dantaylor
Trailering
I didn't realize I had two threads going sorry guys I don't know how that happened I'm not getting any other codes I'm going to download forscan and see if that'll keep me somewhere else I'm just tired of dumping money into this thing of dumped about $5,000 into this truck in the last 3 months and it's still don't run
