Steering Column Bushings
Old Aug 18, 2021 | 06:40 PM
Mushroomman63's Avatar
Mushroomman63
Trailering
Good day all,
So I have a 1963 f100 and I am rebuilding the front end and adding disc power brakes. While I do this work, I figured I should check steering. It appears that in the area where the three on the tree shift linkage arms come out of the steering column, grease is leaking out. The truck was changed to floor shift so I don't need the on the tree shift arms but wasn't sure if there was a way to stop the leak without replacing the whole shaft setup? Any ideas?
Old Aug 18, 2021 | 07:38 PM
john jamieson's Avatar
john jamieson
I don't think there's supposed to be a real seal. It sounds like someone pumped a lot of grease in there to quiet things or make it smooth operating, when one of the bearings or supports wore out.
wmring
Aug 30, 2024 09:29 PM
three.on.the.tree
WTB - Parts & other
Nov 9, 2017 01:32 PM
Blucifer
Nov 19, 2012 07:44 AM
pukey
Dec 31, 2010 04:21 PM
