Sponsored by: Real Truck
Right Ire Pressure
Old Aug 18, 2021 | 06:47 AM
Dieselcyrus's Avatar
Dieselcyrus
Right Ire Pressure
I have a 08 f250 4x4 lariat crew cab. Just installed Nitto G2 37x13.5x20 tires. What tire pressure do any of you that run this size tire on your truck have on yours??
thanks
Old Aug 18, 2021 | 07:49 AM
jav_eee's Avatar
jav_eee
thanks
whatever pressure allows the entire tread to contact the ground to insure the tires wear evenly. Most people call this the “chalk test”. You can also use the dirt on the tread to check. Unloaded you’ll probably be around 40 psi in the rear. You absolutely do not need to run the tires at the PSI indicated on the sidewall unless you plan on loading them to the weight indicated on that same line…
jdb9083
Aug 19, 2013 09:41 AM
turbo740922
1997 - 2003 F150
Mar 1, 2011 11:34 PM
hddad32
Oct 20, 2010 06:03 PM
F250wanted
Apr 11, 2008 08:21 PM
RustyWallace
Jul 21, 2004 07:02 PM
