back pressure.....
Old Nov 1, 2003 | 11:27 AM
wezol5484's Avatar
wezol5484
back pressure.....
i have been hearin that not enough back pressure can wear down on ur engine quickly. well AFTER i cut out my glass pak ive been hearin this and ive never really understood what back pressure does exaclty for ur engine. can some one please help me understand what it does and also if not havin a glass pak will effect my engine. its the stock exhaust so its single and the tip ends amost flush with the back of the cab.
thanks for ur help
Old Nov 1, 2003 | 03:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum from GC.
Old Nov 1, 2003 | 05:05 PM
modru2004's Avatar
modru2004
someone correct me if im wrong. but i think back pressure is when the exhaust gases can't flow out properly and this keeps the engine from getting fresh air and etc. like it should and interferes with combustion.
Old Nov 1, 2003 | 06:23 PM
ctfuzzy's Avatar
ctfuzzy
Well ok. Hush
"Dad" moved it to the proper forum. We are supposed to reply there.
Old Nov 1, 2003 | 06:55 PM
WhëëlMå1's Avatar
WhëëlMå1
Re: back pressure.....
I have never heard that. Backpressure is needed...to an extent. It all has to do with the exhaust gases maintaining enough velocity to make it to the tailpipe. How do you keep velocity? Run either smaller pipes, or a bit more restrictive muffler. Since you have cut the 'pack out, do you plan on putting anything else in its place, or run straight pipes? You should be fine either way with the stock exhaust.
Rich
Old Nov 1, 2003 | 07:28 PM
StrangeRanger's Avatar
StrangeRanger
Re: Re: back pressure.....
Not quite. Back pressure is NEVER desirable. It is an unfortunate by-product of the necessity of maintaining gas velocity. A more restrictive muffler doesn't promote velocity, it only robs power.
Since pressure drop is a function of pipe diameter^4 and velocity is a function of diameter^2, small changes in diameter can yield big changes in pressure. An exhaust system that is large enough to give good flow velocity at 6000 RPM will be too large to give gooat 2000 RPM and low rev performancemay suffer. That is the origin of the "engines require backpressure" myth.
Old Nov 2, 2003 | 12:02 AM
wezol5484's Avatar
wezol5484
yea im just gonna leave it a strat pipe. theres about 2 ft of pipe after it comes the 2 manifolds come into one pipe, if that makes sense. the pipe is 2 1/4 inch dia. so would what i have be better for high revs or low....this back pressure stuff is intresting.
Old Nov 2, 2003 | 07:57 AM
ctfuzzy's Avatar
ctfuzzy
Well OK.
Then just . . . NEVER MIND.
I am completely at a loss now to figure out how this board works. Is there any list of common netiquite rules it is OK to utterly ignore on this particular board, or is it something you learn from experience around here?
Thanks in advance Guys.
Old Nov 2, 2003 | 08:04 AM
StrangeRanger
Your problem is what?
There doesn't appear to be any problem with this thread. Question asked, open discussion, no flames or anger involved, answers evolving. Pretty normal.
Old Nov 2, 2003 | 11:17 AM
wezol5484's Avatar
wezol5484
hey im just an innocent kid tryin to get some info on backpressure lol. i couldnt seem to find ne on like google or w/e so i figured this was my best bet.
Old Nov 2, 2003 | 01:03 PM
StrangeRanger
That reply was meant for ctfuzzy not you, Wezol. He seems to have a problem with something in this thread, I'm curious as to what.
Old Nov 2, 2003 | 04:10 PM
ctfuzzy's Avatar
ctfuzzy
This was the part that confused me.
It lead me to believe this was not the proper place to post replies.
However, more were posted even after it being pointed out that the thread had been moved. So I'm confused.
Old Nov 2, 2003 | 09:49 PM
modru2004's Avatar
modru2004
perhaps you haven't thought of the fact that maybe it was moved from another forum to this one?
Old Nov 2, 2003 | 10:30 PM
wezol5484's Avatar
wezol5484
it was cause i origally posted it in the g/c forum and it got moved here
Old Nov 3, 2003 | 07:13 AM
ctfuzzy's Avatar
ctfuzzy
Heck no it never crossed my tiny mind !!
Duuuuuuh
I would have expected the Admin message to say: "Moved *here* from . . " because it addressed engine performance, I figured it had been moved to the "engines" area.
My most sincere apologies, Gentlemen. Really.
