Sponsored by: Auxito
Reverse Lights Not Working
Old Aug 15, 2021 | 07:16 PM
rustylightning's Avatar
rustylightning
Is there a common issue with the reverse lights not working? Fuse? Switch?
Old Aug 15, 2021 | 07:49 PM
projectSHO89's Avatar
projectSHO89
What are you working on?
Old Aug 15, 2021 | 07:51 PM
rustylightning
forget to add that to post. 1999 f150 2wd 6 cylinder automatic 2 door stepside
Old Aug 16, 2021 | 06:13 AM
projectSHO89
Could be anything from the fuse (F05 in the CJB) to the DTR switch on the transmission to the light bulbs to the ground or any of the connectors in between. You simply have to go through the circuit logically and see where the power is getting lost.
Old Aug 16, 2021 | 04:38 PM
Larryjr03's Avatar
Larryjr03
Please see my previous post. I have no Reverse Lights either. 2003 F150. Have checked bulbs, fuses in the cab and under the hood, disconnected the DTR and jumped pins, and still have nothing. Other folks on this site have been very helpful, but still is not fixed. Anyone else on FTE like a crack at it. Thanks
Where are the grounds for Reverse Lights located, and what color wire ?
Old Aug 16, 2021 | 04:54 PM
rustylightning
Checking lights today
projectSHO89
There is no previous post in this thread. If you created a new thread after having a previous thread for the same issue, that screws things up by fragmenting conversations and should be avoided.
Old Aug 16, 2021 | 04:57 PM
rustylightning
I’m the OP on this thread
Old Aug 16, 2021 | 05:02 PM
rustylightning
So I removed the rear lights and removed the bulb to check for power and ground. Ground on one terminal was good. No power when running and in reverse. We shifted through all gears never any power. So where is the next place to look downstream from the rear taillights
pete/ny
16
Apr 24, 2023 09:26 AM
Sean Roth
Apr 17, 2021 11:35 PM
Seanosu
Mar 7, 2016 09:59 PM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
