Diesel Exhaust Filter
On the way to Colorado from Texas the engine tried to regen several times before showing the check engine symbol and wrench symbol. The dealer up here says the exhaust filter assembly is plugged and needs replacing. I have the Ford extended warranty but they are telling me this work isn’t covered. The price is $6100. Does anyone have any experience with this problem.
Emissions Defect Warranty
Emissions Defect Warranty Coverage
Passenger Cars & Light Duty Trucks:
• 8 years/80,000 miles (whichever comes first) for catalytic converters, electronic emissions control unit, and onboard emissions diagnostic devices, including the Battery Energy Control Module (BECM)• 2 years/24,000 miles (whichever occurs first) for all other covered parts. (Note: Ford’s 3-year/36,000-mile New Vehicle Limited Warranty bumper-to-bumper coverage, surpasses this mandatory federal coverage.).
Heavy Duty Vehicles:
Applies to trucks over 8,500 pounds GVWR up to 19,500 pounds GVWRThe emissions warranty coverage period for heavy duty vehicles (“HDVs”) is 5 years/50,000 miles (whichever comes first) for all parts covered by your emissions warranty.
For important information about vehicles designated as “vocational vehicles” on the underhood “VEHICLE EMISSION CONTROL INFORMATION” label, please see your Warranty Guide.
Emissions Performance Warranty Coverage:
The emissions performance warranty coverage period is as follows:Passenger Cars & Light Duty Trucks:
Applies to vehicles up to 8,500 pound GVWR:• 8 years/80,000 miles (whichever comes first) for catalytic converter, electronic emissions control unit, and onboard emissions diagnostic devices.
Applies to trucks over 8,500 pounds GVWR up to 19,500 pounds GVWR: 5 years/50,000 miles (whichever comes first) for all covered parts.Under Emissions Performance Warranty Coverage, Ford will repair, replace, or adjust – with no charge for labor, diagnosis, or parts – any emissions control device or system, if you meet certain conditions specified in your Warranty Guide.
What is Covered?
For your vehicle if these parts contain an emissions-related defect, they are covered by both the Emissions Defect Warranty and the Emissions Performance Warranty.• Air Flow Sensor
• Air/Fuel Feedback Control System and Sensors
• Air Induction System
• Catalytic Converters (including Selective Catalytic Reduction and Diesel Oxidation Catalysts)
• Cold Start Enrichment System (diesel only)
• Controls for Deceleration (diesel only)
• Diesel Exhaust Fluid System
• Diesel Particulate Filter
• Electronic Ignition System (diesel only)
• Electronic Engine Control Sensors and Switches
• Powertrain Control Module (PCM)/Engine Control Module (ECM)(includes hardware and emissions related software changes only)
• Evaporative Emission Control System
• Exhaust Gas Recirculation (EGR) System
• Exhaust Manifold
• Exhaust Pipe (Manifold to Catalyst)
• Fuel Filler Tube and Seal (non-diesel only) • Fuel Injection System
• Fuel Injector Supply Manifold
• Fuel Tank (non-diesel only)
• Fuel Tank Pressure Control Valve
• Ignition Coil and/or Control Module
• Intake Manifold
• Intercooler Assembly - Engine Charger
• Malfunction Indicator Lamp (MIL)/On-Board Diagnostic (OBD) System
• PCV system and Oil Filler Cap
• Secondary Air Injection System
• Spark Control Components
• Spark Plugs and Ignition Wires
• Thermostat
• Throttle Body Assembly (MFI)
• Transmission Control Module (TCM) and Solenoids
• Turbocharger Assembly
• Vacuum Distribution SystemFor important warranty details and exclusions, or full details about coverage under California requirements for emissions control, contact your dealer or see your Warranty Guide.
And, yes, the extended warranty expressly excludes the DPF Diesel Particulate Filter, just because they are so expensive to replace.
Your choices are limited, pay the dealer the 6100 and go on with your trip.
Find an independent shop and get a used one installed.
Get it towed home and do one of those above solutions.
The DPF can be cleaned and put back on, but not many shops fool with the ones from pickups.
Keeping on driving with the clogged DPF isn't a good option, it will eventually not be able to keep going.
The following users liked this post:
