2005 E-350 with 5.4 gas motor, have had a recurring issue with code P2272 which is stuck lean oxygen sensor, Bank 2 Sensor 2 (downstream). I'll be replacing it soon, will most likely do all four since I'm already in there. LTFT bank 2 seems to drift negative a bit, voltage hovering about 3.5 or so. That's the easy part.
I NEVER buy anything from RockAuto, almost always Motorcraft even if it comes from the dealer but RA's catalog shows only the upstream parts (MC# DY1042) but I'm not having much luck even with a Google search finding the p/n for the downstream parts---who's a good source?
Also are they any truly fully compatible O2 sensors for Ford's 5.4 motors? Whose had repeated good results with other brands? (Cost isn't an issue---don't want anything cheap but problematic).
