7.3 IDI fuel pump?
Old Aug 12, 2021 | 01:36 AM
outinit's Avatar
outinit
Trailering
7.3 IDI fuel pump?
Could anyone tell me if I can somehow use an IDI turbo pump on a non turbo 7.3?
Thx
Old Aug 12, 2021 | 06:59 AM
Olds64's Avatar
Olds64
You can use the turbo pump on a non-turbo motor. Both the lift pump and the injection pump. If your swapping IPs then you should adjust the fuel screw once it's installed on the non-turbo motor (make sure you use a pyrometer) and set your IP timing.
Old Aug 12, 2021 | 11:27 AM
outinit's Avatar
outinit
Trailering
Thanks for that info, much appreciated...a bunch of good relevant threads were auto suggested that helped fill in some blanks too. Thanks FTE , great place great people.
7Peroy7
Jun 25, 2021 09:32 AM
Realslowww
13
May 29, 2015 11:51 PM
Macrobb
May 13, 2014 11:14 AM
1989f250IDI
May 8, 2013 12:27 AM
