Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1965 F800 vin decoder
Old Oct 20, 2021 | 03:06 PM
  #31
Martini130's Avatar
Martini130
From what I’ve read it looks like a edelbrock 1906 would be a equal replacement , trying to get away from Holley
Old Oct 21, 2021 | 07:02 PM
  #32
Martini130's Avatar
Martini130
So would a edelbrock 1406 be the model of a Holley 4160 or edelbrock 1906
Old Oct 21, 2021 | 08:43 PM
  #33
85e150's Avatar
85e150
No idea. If you are dead set on adapting that carb, go with the 1406--600 CFM is plenty for that engine. Like I said earlier, you could put a big 2bbl on there if you want simplicity.
Old Oct 21, 2021 | 09:01 PM
  #34
Martini130's Avatar
Martini130
Ain’t really set on it just ain’t a Holley fan. With the 2 barrel would that have to have a adapter plate for the 4 barrel intake
Old Oct 21, 2021 | 09:23 PM
  #35
85e150's Avatar
85e150
Yes you need an adapter.
Old Oct 21, 2021 | 09:30 PM
  #36
Martini130's Avatar
Martini130
Would that affect the governor or anything? Sorry not real familiar with carbs
Old Oct 21, 2021 | 10:14 PM
  #37
85e150's Avatar
85e150
Are you familiar with tuning the edelbrock?
Old Oct 22, 2021 | 06:56 AM
  #38
Martini130's Avatar
Martini130
Tuning yes. Just never had a vehicle with the governor intake. So a 2 barrel would work with the adapter?
Old Oct 22, 2021 | 05:25 PM
  #39
85e150's Avatar
85e150
OK so you've had this carb off the engine. So what vacuum lines came off the carb and where did they go?
Was there any linkage between the carb and the governor? AFAIK, the governor you have has its own throttle butterflies to close down when the engine speed limit is reached. The only connection should be the vacuum line(s) to the distributor.
Does the governor work?
Once you confirm the connections, you will move those over to the new carb, make sure it's sealed up, and see how it runs.
Old Oct 22, 2021 | 05:50 PM
  #40
Martini130's Avatar
Martini130
yes the only vacuum lines where to the distributor, as far as the governor working that I’m not sure off ,
doesn’t seem to be.
Old Oct 22, 2021 | 05:51 PM
  #41
Martini130's Avatar
Martini130
And there was/is no linkage to the governor from the carb.
Old Oct 22, 2021 | 07:39 PM
  #42
85e150's Avatar
85e150
Ok, so as long as it fits and seals up you should be able to put any carb on top of the governor. As long as the vacuum lines are connected, the governor should work to prevent overspeed.
Don't toss the Holley, but see what happens with a fresh carb.
Old Oct 22, 2021 | 08:29 PM
  #43
Martini130's Avatar
Martini130
I’ll give a shot, got the edelbrock 1405 ordered
Old Oct 29, 2021 | 04:32 PM
  #44
Martini130's Avatar
Martini130
Would anyone have a vacuum line diagram for this motor?
Old Oct 30, 2021 | 09:29 AM
  #45
tripleframe's Avatar
tripleframe
factory fresh '65 391
