What is a good intake plenum volume for a stock rebuilt 300 4.9L inline 6? Truck is just a cruiser, used for mild street driving, no loads.
Motor has headers, electronic ignition, Clifford open 4V 6 cylinder intake with a 4x2 carb adapter and runs a Holley 2300 350 cfm or Autolite 2100 1.08 venturi 2bbl carb.
Want plenum volume as small as is practical for this intake, carb & my driving conditions.
Rich -- Never used a flow bench to figure plenum volume. Just a lot of measuring & cubic inches. I am for sure an old school builder. Thanks
Consider using some plexiglass to seal off the ports and then pour rubbing alcohol into the intake until full. Then dump out the contents into a graduated beaker (think chemistry class) and measure in cubic centimeters (CC).
As far as a specific volume... hell if I know. However, I'd port-match (aka "gasket-match") the intake and radius (with a carbide bit on a die grinder) its innards for smoother flow.
Have not tried the with the Clifford 4x4 adapter, the 4x2 adapter on my truck as medical issues are holding me up working on the truck.
As I have rotated the adapters 90 degrees & installed a plenum divider so 1 throttle bore feeds the 1-2-3 cylinders & other bore the 4-5-6 cylinders I will try the setup like I have it now the first time and get some new AFR gauge readings.
Then if my measurements indicate that the main plenum below the carb has to much volume & will rebuild the 2bbl carb adapter to a 1/2" plate with carb studs. I will bolt it directly to the Clifford Intake & remove the Clifford 4x4 & 4x2 adapters. This change will reduce the main plenum chamber volume.
I don't understand why you want a smaller plenum. Smaller would not be better for the air/fuel flow. A shorter plenum would require the air/fuel to make a sharper "L" once in the intake. This is why a 1" or 2" spacer under the carb on our V8's brings more power to the table. I'd bet that Clifford did their homework.
JEFFFAFA - My way of thinking is that this Clifford 4V inline 6 intake manifold was built to run a 4bbl carb not a 2bbl. If the main plenum section under the 2bbl carb is to big the flow velocity will be reduced and affect the 2bbl operation. FrenchTownFlyer over on the Ford 6 Performance site has years of real time experence with the 300 motor & the Autolite 2100 carb for street use and has found that a smaller main plenum is better with a 2bbl carb. I agree that with a 4bbl a spacer might help.
