Source: Fuel tank strap insulation strips
Old Aug 10, 2021 | 11:47 AM
F-250 restorer's Avatar
F-250 restorer
I need that anti squeak strip that sits between the tank and the straps. LMC and NPD are a no go. Anyone know where I can get it?
Old Aug 10, 2021 | 12:42 PM
redroad's Avatar
redroad
There are many products. Just measure the width and decide whether you want the strap to sit inside it or just simply placed under it.
resonateur's Avatar
resonateur
You can use canvas webbing, cotton belt or rubber strips. Just contact glue it to the metal straps.
Old Aug 10, 2021 | 03:37 PM
bigfoot22's Avatar
bigfoot22
As mentioned before. Rubber. Bicycle inner tube.
cut to fit.
Old Aug 10, 2021 | 03:52 PM
EQCMCAT's Avatar
EQCMCAT
If you can get your hands on an old piece of conveyor belt, you can cut to size, clean the straps and use a good rubber adhesive.
Old Aug 10, 2021 | 06:24 PM
Lrrr-RulerOfOmicronP's Avatar
I just bought some rolls off Amazon.
Amazon
Old Aug 10, 2021 | 08:50 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
JBG https://shop.broncograveyard.com/197...ctinfo/20359A/
X2 on old inner tube, canvas, conveyer belt or old ratchet strap material. Remember any material that can hold moisture, can lead to rusting. Heck even rubber can trap moisture. Here is the PO hack job, yes I think that is bondo in there. And yes the tank held for quite a while them started leaking in the rear passenger side corner. Coat the underside of the tank with some DIY roll on bed liner or spray undercoating BEFORE you put the straps back up.
Yes I used old ratchet strap, because I did not know any better at the time.
https://www.summitracing.com/parts/o...hoCQwAQAvD_BwE
Old Aug 11, 2021 | 09:59 AM
F-250 restorer
That was a great point about the roll/spray-on liner, 78&79 f250. I'm changing both tanks. The rear is 38 gallons and I had to delete the spare tire holder. Tired of it. The side hasn't been used in ...10+ years and thought it'd be easier to replace than restore.
But tanks are on back order until October!! Grumble. I'm going on a long trip and wanted to have a working fuel gauge to calculate mpg.
Thanks for all the ideas/responses about the straping material.
mrlightrail
Jul 9, 2008 02:42 AM
