Alternator not charging
Old Aug 9, 2021 | 09:49 PM
DannyBroocker's Avatar
DannyBroocker
I’ve got a 1974 F250 with a 390FE and I have a few accessories that require an alternator above 65 Amps so I bought the same type, 1g, 4 wire, 100 amp. The first time I put it in it didn’t charge my battery which was odd, so I put the old 65 amp back in and that wouldn’t charge my battery either after it literally just did an hour before. It ended up being a bad voltage regulator so I replaced that with a 12v one from oreilys. Well I took the new 100 amp alternator to oreilys to get tested because I’ve put it in about 5 times and it still doesn’t charge, and it tested good, so I went home and put it back in today and reclocked the alternator to see if that would change anything and it didn’t.
Im so lost because my 65 amp alt charges it’s just not big enough so I need to get this 100 amp to work. No fusible links are blown, I actually converted them to regular fuses. Im just so lost I have no idea what to do. The ground wire is new and runs straight to my battery to see if that was the problem and it wasn’t.
If anyone can help, I would greatly appreciate it.
Old Aug 9, 2021 | 10:12 PM
redroad's Avatar
redroad
Does the 1G have a built in voltage regulator? and if so are you altering your wiring to accommodate that?
Old Aug 9, 2021 | 10:20 PM
redroad's Avatar
redroad
My bad the 1G is still externally regulated.
Old Aug 9, 2021 | 10:31 PM
redroad's Avatar
redroad
The 1 wire is a 2G and not 1G is my understanding and it is not an externally regulated alternator.
Old Aug 9, 2021 | 10:39 PM
DannyBroocker
I’m not sure if this will help but here’s the new one I got.
https://www.summitracing.com/parts/s.../ford#overview
Old Aug 9, 2021 | 11:00 PM
redroad's Avatar
redroad
From the description it says "no on 1 wire capable" and externally regulated. So It's definitely 1G. So from the 1G wiring diagram from above can you see any mistakrs in your current wiring set up ? Maybe tomorrow in the day light double check it. If still no joy post back and we'll go from there. A guy needs a 100 amps these days
Old Aug 9, 2021 | 11:11 PM
DannyBroocker
Thanks redroad! I’ll check it out tomorrow and get back to ya.
Old Aug 10, 2021 | 07:39 PM
DannyBroocker
So I went through my wiring again and all looks good, except for the field post on the alternator is not getting power at all, which I believe means a bad voltage regulator. I replaced the voltage regulator not too long ago so that would be odd but I’m going to pick up a new one.
Old Aug 10, 2021 | 08:11 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Make sure the voltage regulator is grounded good, after installing and removing the screws they get loose. It will blow the regulator if not, I went thru several before I was told to ground to the battery.
Old Aug 10, 2021 | 08:54 PM
DannyBroocker
The regulator has a good ground. The FLD post is still getting no power, and I checked the STA post and that’s not getting power either.
However, I’ve got another question. With both the old and new alternator, there’s a 5th post on it with no writing next to it. With the 65 amp, the ground wire ran to that, leaving the post labeled “GRD” empty. With the new alternator, I moved the ground to the “GRD” post but it still didn’t change anything. What would be the reasoning behind that? Is that why the other posts on the alt aren’t getting power, because it’s not grounded properly?
Old Aug 10, 2021 | 10:31 PM
redroad's Avatar
redroad
This is where pictures would come in handy. If you could take some tomorrow please.
Old Aug 10, 2021 | 10:34 PM
DannyBroocker
This is the 65 amp but the 100 amp is identical. As you can see, the ground was not on the GRD post, but rather the empty post.
Old Aug 10, 2021 | 11:16 PM
redroad's Avatar
redroad
They both serve the same purpose.
In the cab do you have a meter or a light for the charging system ?
Running ignition power to the "S" terminal of the regulator is the way the factory wired it when the truck had gauges and no dash light.
Dash warning light wiring =uses the "I" terminal and it must be hooked to a dash light and then key-on power. This brings the alternator online to charge.
The other way to hook it up leaves the "I" terminal blank, the "s" terminal on the alternator is blank, and the "s" terminal on the regulator goes to a key on power source. This brings the alternator "online" also to charge.
Old Aug 10, 2021 | 11:23 PM
DannyBroocker
I used to have the ammeter with my dash but now I have https://www.intellitronix.com/produc...placement-dash so its an electronic reading now.
So the main wire for the ammeter isn't hooked up. Could that be a potential problem?
Old Aug 10, 2021 | 11:38 PM
redroad's Avatar
redroad
That's probaly the problem there. Reread the above post I edited it. You should be able to find the red/green up at the cluster plug somewhere if you do not want to run another wire to the "S". You will just have to get it and re-wire it to a ignition hot and that should fix it.
Is it wired now where the gauge cluster is wired with the "I" blank, the "S" on the alternator blank, and the "S" on the reg wired to a key-on hot ?
Nice dash BTW !
